    [Bug] Ctrl+A does not work in explorer view
    15 Posts 7 Posters 17.0k Views
    • ? This user is from outside of this forum
      Guest
      The menu commands Large Icons, Small Icons, List and Details don’t work in explorer view. If I select one of these options the status of the menu command changes but nothing happens with the icons in the explorer view.
      ? 1 Reply Last reply Reply Quote 0
        Guest @Guest
        The submenu “Arrange Items by” is grayed out in explorer view so that it is impossible to sort the items with keyboard or menu. Also the “Refresh” command is grayed out.
          spwolf conexware @Guest
          @postman:
          thats because they can be only used when archive is open. We will tie them in with Explorer view (w/o archive open) for 9.1.
          thanks,
          • SpAwN oF T.D.F.S Offline
            SpAwN oF T.D.F. @Guest
            At me it works… :D
              spwolf conexware @SpAwN oF T.D.F.
              I have grouped all of the “explorer view” threads into one, for future version wishlist. We had to change our explorer view very close to release date since our old one started having issues in Delphi 7.
              There are plenty of missing features in Explorer view, even in addition to ones posted here, and hopefully we will take care of all of them for 9.1.
              thanks,
                spwolf conexware @spwolf
                p.s. to clarify, this is for explorer view, without archive open.
                R 1 Reply Last reply Reply Quote 0
                • R Offline
                  rev23dev @spwolf
                  does that mean drag and drop folders in explorer view will be taken care of for 9.1?
                  :cool:
                  spwolfS D 2 Replies Last reply Reply Quote 0
                    spwolf conexware @rev23dev
                    @rev23dev:
                    :cool:
                    You mean as in archive paths? Nope, this is only for explorer view, without archive open. But having support for drag & drop of path folders would be nice definetly, and please keep mentioning it :)
                      daft @rev23dev
                      @rev23dev:
                      :cool:
                      I really hope so. This is the ONLY reason why I prefer WinRAR over PA. I’m amazed that so few archivers support something as simple as this. I’d be very pleased if the new PA can do this.
                      ivanI 1 Reply Last reply Reply Quote 0
                      • ivanI Offline
                        ivan conexware @daft
                        Thanks!
                        Explorer view improvemetns will be made for 9.1.
                        G 1 Reply Last reply Reply Quote 0
                        • G Offline
                          Guestus @ivan
                          Huge feature missing: pressing a letter on the keyboard doesn’t take you to the folder that begins with that letter. That’s very uncomfortable and annoying. Please…fix it.
