On installing the program I am getting the error message:
"Unable to execute file c:\Program Files\PowerArchiver\pashutil.exe
CreateProcess failed: code 2
The system cannot find the file specified"
This can’t be right!
I am using the latest official build of Windows 11
@lxworld what version of PA? And what AV afe you using?
Thanks!
I have installed the latest beta on windows 11 pro and it work ok, I use mcafee. If the file is in the folder, as I suspect it should be, then it could be a permissions thing on your system. One way to test its’s not your antivirus doing this is to temporary disable it and try loading / installing powerarchiver. If that works its your antivirus.
Another solution is to install to a different folder to see if the program folder is locked permission wise.
I would suggest listing your windows 11 build and specs on computer.
