    Support for mobile devices and android?
    Chris Steinbeck BellC
    Hello. I would like to know if there is some way to open .pa files on mobile devices such as the ones using android. I wanted to use it on my samsung phone but i could not find an app or something that would let me to open those files. Do somebody knows how to open them or could it be that there is a powerarchiver ver for mobile?. Thanks in advance.
    General (Testing, Performance, Usage, Questions)
    Make .PA open to others programs?
    Good morning, I bought Powerarchiver Toolbox because I find the .pa format brilliant! The problem with this format is that only Powerarchiver can open it, so it won’t be as famous as the .rar or .7z! In my opinion it is okay to have the exclusive of the creation of the format, but not of the extraction, otherwise it will never be used by anyone because few people have Powerarchiver! I hope that one day the other extractors will be able to extract the .pa format, I will be able to create archives and send them to whoever I want!
    PowerArchiver 2019 Toolbox International with Advanced Codec Pack
    Hi, I have such a problem. 03.09.2020 I bought this program, I received the registration data that I entered into the application (copy and paste), the application restarted and again reported that it is not registered. I tried it several times, online and offline, I logged in to the web account, I sent the activation email again, I entered its data, but I still can’t register it. So I wrote to support and on September 3, 2020, three hours later, they sent me a screenshot that they managed to activate the program. I thought I might have something to do with windows, so I reinstalled. But that didn’t solve the problem. It cannot be activated in either version 19.00.59 or version 20.00.53. When I wrote them that I still can’t do it, I even sent it to them both in screenshots and in the video, even after reinstallation, and I even attached a dxdiag file to them, so they don’t even answer me anymore and I don’t know what to do with it :-( It’s been a week since it was shipped. Any suggestions please? Thanks.
    Poor compression of >20GB exe/msi/cab sample
    N
    It was raised poor PA compression ratio: Uncompressed: 21,657,900,590 bytes 7-Zip (your package): 2,662,732,158 bytes PowerArchiver 17.00.90 (Optimize Strong): 3,398,179,937 bytes Find package at: https://mega.nz/#!0aRDiAKQ!lrwtC64jnkk4d0ZKjcVGgLKPCcOqyUSyAQ62JJtQZOM[/QUOTE]
    Advanced Codec Pack - engine list of changes
    Here is the list of changes for Advanced Codec Pack engine 13-12-2016 09:56 vE4 zstd2 enc. progress reporting fix plzma4 progress fix plzma4 buffering changes 21-12-2016 00:10 vE5 initial version of x64flt4 25-12-2016 06:39 vE6 x64flt4 update single compressed stream instead of 3 rc speed opt compression improvement rc flush after 256k bytes without any addr output x64comp filter, for addr stream compression with bcj2/x64flt3 25-01-2017 10:11 vE7 mpzapi filter potential support for external executables as .pa filters potential support for executables that don’t work with stdin/stdout (via winapi hooks) 26-01-2017 13:18 vE7 lepton filter, same exewrap lib bugfix: “Data error” with mpzapi when extracting non-solid archive 27-01-2017 07:48 vE7 lepton fallback: files are now stored if lepton quits without writing anything bugfix: lepton inputs that can’t be correctly restored are now reported during compression, not decompression bugfix: remove mpzapi.exe crashes during extraction 31-01-2017 07:44 vE7 packmp3 support 10-02-2017 20:00 vE7 plzma MT bugfix 12-02-2017 22:16 vE8 lepton fix to use two output streams; s0=fallback, s1=lepton lepton fix to use chunksize param for fallback; lepton:c=400M uses 400M inpbuf 13-02-2017 08:47 vE8 bsc support added (as “bsc3”), with :c#M,:x0,3-6,:a1/2 as params 13-02-2017 23:39 vE8 bsc3: added lc param - lc0-lc2 means cf/cp/ca, lc4 means -r; (lc6 = -ca -r) 20-02-2017 12:19 vE8 plzma4: 32-bit outpos bugfix plzma4: loop_enc EOF check fix 26-02-2017 19:51 vE8 bwt1/qlfc filters added 27-02-2017 05:30 vE8 divsufsort.dll rebuilt with gcc 28-02-2017 04:46 vE8 bwt1: chunksize bugfix bwt1/qlfc: disable chunksize alignment to 1M 01-03-2017 22:26 vE8 added qlfc2:mt=#:c=# - qlfc with integrated MT wrapper 03-03-2017 14:58 vE9 updated qlfc2/MTwrap added bwt2:mt=#:c=# 08-03-2017 06:56 vE9 BUG: plzma4 decoder memory leak BUG: workaround for divsufsort’s inverse_bw_transform doing nothing for n=1 09-03-2017 09:31 vE9 BUG: 7z function CHandler::IsFolderEncrypted is buggy (outdated) update bwt1 to 5N version (was 6N) x64flt3: remove zero padding at the end (left from debug) 10-03-2017 07:52 vE9 reflate update to ver 1l2 (bugfix) 10-03-2017 13:41 vE9 BUG: ppmd_sh incorrectly parses memory size BUG: ppmd_sh UpdateModel bugfix 13-03-2017 12:08 vE9 added coro_init() call to deltb::Init() 14-03-2017 17:25 vE9 BUG: all x64flt filters got stuck on files shorter than 8 bytes 15-03-2017 05:57 vE9 7z k_Scan_NumCodersStreams_in_Folder_MAX limit increased to 512 17-03-2017 15:45 VE9 reflate speed optimization (23% faster on x64, 8% on x86) 20-03-2017 03:30 vE9 BUG: lepton failed during encoding of some files; added exitcode check 25-03-2017 04:32 vF0 switched default encryption to winaes 30-03-2017 09:28 vF0 BUG: sometimes there’s not enough memory for winaes decrypting 04-04-2017 19:15 vF0 added MTwrap-based MT zstd as zstd3 - seems incompatible with zstd2 for some reason 06-04-2017 14:57 vF0 zstd3: update to 1.1.4 library 06-04-2017 15:31 vF0 zstd3: fall back to zstd 1.1.0 - 1.1.4 is slower 22-04-2017 17:42 vF1 plzma (plain single-threaded one) bwts,bwtsh,bwtsl,bwt1h,bwt1l,cdm,cdm2 24-04-2017 04:49 vF1 bwt2h,bwt2l mtwrap min_chunk workaround 06-06-2017 02:57 vF1 BUG: bwt2,bwt blklen=2 incorrect handling mtwrap decoder buffer increased to 2*chunksize mtwrap/bufring anti-MT updates IC17->IC18 for x64 build 08-06-2017 20:18 vF2 rep2 = rep1 + MTwrap // :c -> :d added PPMD codec from original 7z (vH) 14-06-2017 13:07 vF2 BUG: zstd cQuit called instead of dQuit 15-06-2017 13:27 vF2 BUG: mtwrap used memcpy on overlapped memory BUG: mtwrap had duplicate memcpys partial buffer flush at the end of BWT2 block updated version_info 16-06-2017 09:33 vF2 !!! all mtwrap codecs lost compatibility (rep2,cdm2,zstd3,bwt2,bwt2l,bwt2h,qlfc2) !!! BUG: mtwrap handling of l=0xFFFE blocks BUG: mtwrap handling of l=0x0001 blocks 17-06-2017 12:20 vF2 restored vF0-compatible zstd3,bwt2,qlfc2; test scripts included BUG: freezing bug is finally solved by adding dynamic buffering to MTwrap decoder mtwrap decoder input buffer reduced from 2C to 1C following codecs use MTwrap_v3: BWT3,BWT3H,BWT3L,QLFC3,cdm2,rep2,zstd4 18-06-2017 23:00 vF2 BUG: another mtwrap freezing bug - mtwrap didn’t notice when thread with empty input quits without outputting anything 32-bit variable was used for thread EOF flags, so max mt32 was supported; updated to 64. 19-06-2017 20:09 vF2 BUG: freezing/data error in zstd4 21-06-2017 16:01 vF2 BUG: data errors in bwt3 refactored mtwrap/loop_dec 21-06-2017 22:54 VF3 archive cleanup modded packmp3 for mp3 compression 25-06-2017 21:11 vF3 ppmd_sh2 added (dX can be used instead of mem=X) ppmd_sh reverted back into enc/dec template 01-07-2017 13:02 vF3 alpha version of mp3det+packmp3b combo (x86 and x64 are incompatible) 02-07-2017 21:14 vF3 packmp3b updated with mtwrap 03-07-2017 06:41 vF3 BUG: x86 version of packmp3b crashes on decoding (problem with IC and floats; /fp:strict fixed it) BUG: memory leak in packmp3b BUG: crash on decoding of test4a.mp3 04-07-2017 18:14 vF4 source cleanup removed some experimental codecs etc 06-07-2017 11:31 vF4 BUG: packmp3b formats created by 32-bit and 64-bit 7z.dll are different packmp3b compression slightly retuned towards 320kbit 16-08-2017 22:53 vF5 reflate2 = reflate/mtwrap; eg. reflate2:x9:c10M 27-08-2017 16:23 vF5 dropped packmp3,packmp3a codecs (and corresponding .exe) added lepton2 aka lepton-slow-best-ratio 11-09-2017 07:10 vF5 added precomp as precomp:mt4:c64M 12-09-2017 08:20 vF5 BUG: fixed precomp to not use same tempfile names in all instances disabled console input in precomp on file overwrite enabled ZIP/PNG/PDF/GZIP parsing in precomp updated precomp handler 13-09-2017 12:30 vF5 added jojpeg for jpeg compression (solid and with detection, but slow); s0=bin, s1=compressed 14-09-2017 15:23 vF5 added packmp3c (2x slower than packmp3b, 1-2% better compression) 15-09-2017 15:03 vF5 packmp3c bugfix (scfsi flags), a little worse compression 19-09-2017 16:00 vF5 BUG: forgot coro_init for jojpeg 19-09-2017 17:12 vF5 updated precomp to 0.4.6 20-09-2017 01:37 vF5 jojpeg switched to gcc dlls (35% faster)
    Some test results of mp3 to .pa .pa experimental
    pirrbeP
    Experimental Codecs - info, updates
    This is a thread about Experimental Codecs used with PowerArchiver when Experimental Codecs check is used. Currently used Experimental Codecs (from PA 17.00.81) : mp3det filter + Packmp3b codec = mp3 codec, currently around 2.5% better compression than WinZip ZIPX and 3x faster speed on 8t cpus. *** Please note, experimental codecs are for testing purposes only and will be used only when experimental checkbox is checked. Quite likely there will be no backwards compatibility with finished versions of codecs, so please use it only for testing.
    settings for wav/sf2 files (from 17.00.68)
    thread for delta/plzma4:a0 settings discussion, moved from: https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69 since on version specific thread it will be pushed back on thread list quite fast.
    Releasing unpacking library
    J
    Do you plan to release unpacking library, so 3rd party software can extract PA format as well? It would be great and certainly would expand the format.
    brilliant format
    this format compresses word files better than rar zip and 7zip thanks powerarchiver
    Optimized Strong, initial tests speed/compression
    Hello @Alpha-Tester . Lets test a bit Optimized Strong methods and see what works and what can be improved. Relationship between codec and filter paramters as well as number of threads is complicated ones, and while we have tried to automate it in the best possible way, improvements are still possible. @skypx has a nice cpu for testing 16t performance for instance. It would be interesting to see whats maximized performance for Optimized Strong Maximum and Ultra options because they use different entropy models (a0 lzma, a1 or lzmarec) which provide different performance - lzmarec is much stronger but also slower to extract where our parallel decode helps. Debug mode can help to log all of this.
    Filters: Reflate - (pdf/docx recompression)
    Filter: Reflate What is it? Reflate is advanced deflate recompression filter designed to improve compression of files with deflate streams. Obvious examples are pdf, docx, xlsx, swf, png but deflate streams can be found in many other files, usually in form of png images. Where to use it? Optimized Strong mode - PowerArchiver will compress all pdf, docx/xslx, pngs, swf, etc, files with Reflate filter automatically. PLZMA4 codec - You can enable reflate filter. Advantages Much better compression of PDF. DOCX and other files with deflate streams. Between 30%-50% on average (vs 5% for regular archivers). PDFs that are mostly big pictures wont be compressed well (especially if it is jpegs), but it will still be substantially better than regular codecs. Disadvantage: Slower speed. Examples: FY17_Proposed_Budget_Vol_1.pdf (Austin Texas Budget 2016/2017) - 20,157 kb PowerArchiver (Extreme): 9,994 kb WinRar (best): 18,356 kb 7zip (Ultra) : 18,336 kb WinZip (Zipx/Lzma) : 18,411 kb oig-work-plan-2016.pdf (Office of Inspector General plan 2016) - 4,165 kb PowerArchiver (Extreme): 1,346 kb WinRar (best): 3,790 kb 7zip (Ultra) : 3,791 kb WinZip (Zipx/Lzma) : 3,784 kb Analysis: Good case scenario. Images are likely pngs, and a lot of text that can be compressed great.
    FMA-REP - info and test results (.pa)
    (This article is work in progress) What is fma-rep? Deduplication filter based on anchor hashing. Technically LZ77, but has no entropy coding, and only longer matches have a chance to be replaced with a reference. It has much lower memory requirements than lzma, so can be used to compensate lzma’s smaller window/dictionary size. Examples: Official ISOs from Microsoft for Windows 10 Pro and Office 2016: Due to large file sizes, and the fact that fma-rep takes a lot less memory than plzma4, it is very useful for large software installation DVDs that have a lot of compressed data already. Best idea is to use large window of fma-rep1 and fast codec, to achieve good compression and yet very fast speed. Tests AMD FX8320 with 16GB RAM and SSD Office 2016 Pro ISO - 1,985,392 kB .pa (Zstandard2, x64flt, bcj2, fma-rep1) 36s encode, 37s decode - 1,551,741 kB .rar (Normal) 128s encode, 13s decode, 1,892,471 kB Windows 10 Pro ISO .pa (Zstandard2, x64flt, bcj2, fma-rep1) 87s encode, 77s decode - 3,577,849 kB .rar (Normal) 314s encode, 27s decode - 3,838,188 kB Sharepoint Server 2013 .rar (Normal) 369s encode, 15s decode - 2,269,782 kB .zip (WZ 21 Normal) - 47s encode, 13s decode - 2,305, 755 kB .pa (Zstandard2, x64flt, bcj2, fma-rep1) - 61s encode, 41s decode - 1,955,468 kB
    Scheduled Pinned Locked Moved Solved General (Testing, Performance, Usage, Questions)
    14 Posts 4 Posters 3.5k Views 3 Watching
    • F Offline
      farkpoint
      Thanks.
        Worked fine with new codes, closing this one… thank you!
          hi @farkpoint
          I have replied to the support ticket with further information on registering PowerArchiver.
          Admin privileges are needed and I have included further information in my reply on support.
          Please let us know there if that helped, we’ll make sure you’re registered.
          • F Offline
            farkpoint
            Hi, I’m sorry for the long pause, but I tried it on another PC, on my PC with other versions of Windows, and I figured out what the problem was. When I downloaded the 64-bit version of MSI version 19.00 build 57 PowerArchiver 2019, the program registered after installation. If I let the new versions check and install the new version 19.00 build 59, the registration will no longer work. So the problem is not in my system, but in the registration data. Since I purchased lifetime upgrades and free support, why can’t I register a version other than 57? Therefore, please correct the registration information so that I can also register the PowerArchiver 2021 RC1 build 55 version.
            Written in support of 14. 9. 2020 22:42:41 and no answer … :-(
            Brian GregoryB 1 Reply Last reply Reply Quote 0
            • F Offline
              farkpoint
              [PA-WTG-NKWMV-821]
              Is it a ticket number?
              From 14.09.2020 no response. I paid for the program than three weeks ago and I still haven’t received a working product. I expected to have full support as a paying customer and not to wait for someone to remember me. Moreover, when it is already clear what the problem is, then I do not understand why it is so difficult to send me the correct registration data ???
              • Brian GregoryB Offline
                Brian Gregory Alpha Testers @farkpoint
                @farkpoint said in PowerArchiver 2019 Toolbox International with Advanced Codec Pack:
                Normally the install files are .exe files, and you get one .exe containing both 32 and 64 bit versions. Where did you get this .msi file from?
                Which version did you buy?
                As I understand it the upgrade from 2019 version to 2021 version is not normally free.
                F 1 Reply Last reply Reply Quote 0
                • F Offline
                  farkpoint @Brian Gregory
                  Here: https://www.powerarchiver.com/download-powerarchiver
                  **I bought this so I assume I have a lifetime version and free upgrades.
                  PowerArchiver 2019 Toolbox International with Advanced Codec Pack + PowerArchiver Select - lifetime free upgrades and support.**
                    Try not using the .msi version.
                    I didn’t even know they existed.
                    Maybe there is some weird restriction with the .msi versions.
                    • F Offline
                      @Brian-Gregory
                      I tried msi the last one last time. When I download version 19 build 57, my registration will be recognized. However, when I update to version 19 build 59, he wants to register it again and does not accept registration data. And not even in version 21.
                      • F Offline
                        farkpoint
                        Hi, I have been working with you for over a month that my registration data does not work and nothing has been resolved. Is it so hard to block registration data that don’t work for me and create new ones for me? I paid for a program with a lifetime license and updates on Sep 3, 2020 17:05:41 in the amount of € 19.98 EUR. Support will come up with something to help me again and it won’t take 2 weeks. Do you get the order that 41 days after paying for the product, I still do not have functional registration information and therefore can not use the program? Now it’s been 3 weeks since I wrote them off and since then no one has called …
                          I said try NOT using the MSI version.
                          I really doubt a genuine with lifetime upgrades version would have only cost €19.98.
                          Where did you buy it?
                            @farkpoint
                            we have replied to your support query regarding the issue.
                            The same code you are using works fine in our tests and the newly generated codes also work.
                            We can generate a new code again, if needed.
                            We have not had any other reports from other that detail the same issues, seems to be a specific problem but we’ll do our best in assisting to solve it.
                            • F Offline
                              farkpoint
                              Hi, can I request a refund? It doesn’t work for me anyway, and no one knows why, let alone fix it. Although I’m sorry, I like the program, but since I can’t use it, I would like to receive payment back. How should I proceed, please?
                              Thanks a lot.
                                Mili conexware @farkpoint
                                Hey @farkpoint
                                sorry to hear that, we will work out the refund and I will send you an email with the details.
                                Thanks
