    Open source
    Could powerarchiver be open sourced as I fear it is going to be lost once you decide to stop development on it.
    PowerArchiver and PACL for macOS
    16 Posts 7 Posters 15.4k Views 4 Watching
      Dear @Alpha-Testers and all of our users,
      time has come for testing of PowerArchiver and PACL for macOS.
      Please let us know here if you have Mac and can test latest builds.
      Features implemented:
      PowerArchiver 2020 - tabbing, opening, extracting, adding, testing, favorite folders, support for multiple languages, opening via Finder, explorer mode, installer.
      PACL 10 - support for most formats and features in Windows version.
      Upcoming: Tools such as archive converter, batch zip, multi-extract.
      To start testing, please sign up here in this thread, and we will send you latest build.
      thank you!
      Ashampoo_Snap_Wednesday, November 20, 2019_12h54m56s_008_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h55m05s_009_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h55m14s_010_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h55m30s_011_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h55m39s_012_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h55m49s_013_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h56m00s_014_.png Ashampoo_Snap_Wednesday, November 20, 2019_12h54m43s_007_.png
      G 1 Reply Last reply Reply Quote 0
      • guidoG Offline
        guido
        cant test, dont have a Mac (Thank God).
        Windows 11 Pro ENU x64
        Intel Core I7
        32 GB RAM
        spwolfS 1 Reply Last reply Reply Quote 2
          spwolf conexware @guido
          @guido said in PowerArchiver and PACL for macOS:
          • G Offline
            galvanic.lucifer @spwolf
            @spwolf Hello, I’d like to test the macOS builds.
              spwolf conexware @galvanic.lucifer
              @galvanic-lucifer said in PowerArchiver and PACL for macOS:
              sent via message. Public testing will start soon.
                moggoly
                Hi @spwolf Came to this a bit later than others, but lifetime select user here, and I’d like to help test the MacOS version please. MBP 15" 2016 w/touchbar 16Gb RAM running Catalina. Do I need a new license number for this? I downloaded from the main download page but it won’t accept my activation code.
                Cheers.
                • Y Offline
                  yykian
                  is the testing still available? I have a Macbook Air 13" 2015 running on Big Sur
                    hi guys, please contact us at support at conexware dot com and we’ll sort it out.
                    thanks!!
                    • Z Offline
                      ZebraPower
                      Latest version crashes instantly on MacOS 12.0.1 on an M1 MacBook Air. I was prompted to install the Intel Rosetta Translation first (which I did). Hopefully a native M1 (arm) port is in the works.
                      I sent a copy of the crash log that it wanted to send apple to the support e-mail you typed above.
                        spwolf conexware @ZebraPower
                        @zebrapower said in PowerArchiver and PACL for macOS:
                        thanks for letting us know, did it work previously with M1 cpu?
                          spwolf conexware @spwolf
                          @spwolf said in PowerArchiver and PACL for macOS:
                          There is also latest release, please check it and let us know:
                          https://powerarchiverdl.cachefly.net/macos/powarc-macos20001.dmg
                          Z 1 Reply Last reply Reply Quote 0
                          • Z Offline
                            ZebraPower @spwolf
                            Edit: While the program runs, it won’t open any archives that PA2021 for PC creates and/or opens. I have a few zpaq and a few .pa archives and the zpaq nothing happens and the pa it says it’s not a valid PA file yet it opens and extracts fine on PC.
                            @spwolf Hi, thanks for getting back. No I am a new customer to the macOS version so I’ve never tried to run PA on macOS or Apple hardware (Intel or Arm).
                            I’ve downloaded the linked version and it appears to work. It launches and let me start a trial and register it just fine. It even associated with supported formats as well. I’ll test more over the holidays when I can.
                            I noticed it’s still an Intel app. Will there be plans to port it to arm eventually?
                            Thanks again!
                              Thanks again!
                              Hello, by “any”, you mean .pa and .zpaq formats? We do not have same engines in Windows and Mac versions, but we keep adding more and more features. Keep in mind that Windows version has been built over the past 20 years, moving full feature set will take a bit.
                              There are plans to do arm version in 2022.
                              thank you!
                              • Z Offline
                                ZebraPower @spwolf
                                @spwolf Sorry, yes I didn’t test all formats that PA supports, just .pa and .zpaq. I had existing PA2021 archives on a network share that the MacOS version wouldn’t open. I moved them to the Mac’s desktop off the network share and it still didn’t open. They open fine on PC and another app opened the .zpaq archive and tested ok.
                                I understand PA for MacOS is new, and I’m not upset or disappointed. I’ve been using it on PC for a year or two now and it works great. Glad to help test. :)
                                • Z Offline
                                  ZebraPower @ZebraPower
                                  Hi all. Any updates on an M1 native version or an Intel version that works on M1/M2 Macs?
                                    Mili conexware @ZebraPower
                                    Hi @zebrapower
                                    With PA 2023 first version now being finished, we will start working on the MacOS version as well. I’ll update this topic with any information about m1/m2 support and/or versions to test.
