    pacl900b-190606.exe (PACL 9.0 Beta 5) pacomp -r not working.
    I’m trying to backup the complete contents of a directory using: pacomp64 -parcz T:\BACKUP.PA C:\STUFF The contents of subdirectories of C:\STUFF isn’t getting backed up! The sub directories are just stored as empty directories!
    When extracting 7z files extract only newer files
    B
    How do I achieve this ; show me a command line example !
    Question Regarding License
    Hello @Mili, thanks for your help in getting my PowerArchiver CommandLine license (Re: License Code Not Working / Missing) and sorry for my late reply. I do check my spam folder regularly and couldn’t find a mail from support. Also, there was no mail in my backups or any mention of it in my email logs. I have a question regarding my licenses in the hope you are able to help me: While my account lists “PowerArchiver Select - lifetime free upgrades and support for PowerArchiver Toolbox English - Count 2”, this does not apply for PACL, which was included with my purchase. My account shows only PowerArchiver Select - 12 months of upgrades and support for PowerArchiver Command Line - Single User License. Since PACL was included with PowerArchiver Toolbox, shouldn’t PACL also come with a lifetime license for 2 PCs? Thanks for your help in advance.
    PACL 9.0 Beta 2
    Version: PACL 9.00 Beta 2 What’s New since version PACL 7: Updated to PowerArchiver 2017 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support and all the various engine updates done in PA 2017. Full support for .PA format with many different options and switches. Download: http://dl.powerarchiver.com/2017/PACL900-170429.EXE Due to the support of new PA format and all the changes needed for that support, we decided to move up version number to PACL 9. This is purely cosmetical - companies who purchased PACL8, have PACL9 now added to their orders. Users who have free upgrades for PACL8, now have PACL9 added as free upgrade (Business users with active select (pro/tbx), all personal users (pro/tbx). Since we are finalizing PA 2017, we can also now spend a lot more time on PACL9. Please check your bugs, and check .PA support as well. Thank you! @Alpha-Testers PA Team ConeXware, Inc.
    The PACL does not extract files from the self-extracting archive
    Michael72M
    My OS: Windows XP Home Edition, SP3 The version number and date of the program: PowerArchiver Command Line v9.00b [Feb 23 2019] The program not extracts one self-extracting file. How to reproduce the problem Download the SFX file by link: install.exe Copy the “install.exe” file into the same location as the program is located. Go to the DOS prompt. Make your PACL location the default drive. If it is on the E drive enter the command E: and press enter. Replace “E:” with the appropriate drive letter. Enter command cd e:<path name> to go to the location where the program resides. Enter command: paext32 -o+ -p"install" "install.exe" As a result, the “install” directory will not be created and no files will be extracted. The “install.exe” file may be damaged but if you use a program such as 7-Zip or PeaZip to extract the files, the extraction process is successful. I want the PACL to also unpack such a file. This problem is very critical for me. I often come across this. I do not want to resort to using other compression program. … Michael
    PACompXX problem with file name syntax
    czip support
    would be nice to have czip support
    PACL 8.0 Beta 1
    Version: PACL 8.00 Beta 1 Whats New: Updated to PowerArchiver 2016 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support such as improved ZIPX, ISO, etc, etc, etc. Download: http://dl.powerarchiver.com/2016/pacl800b1.exe Please test it against your existing scripts and let us know. There will be some features added in future release as well as more testing. This is first release, please test. Thank you!
    pacomp-exe-has-stopped-working)
    P
    I am Having Appcrash mid problem in my Pc.
    PAConv.bat
    Hi, I’ve made changes to fix some problems with PAConv.bat: 1. Replaced the “” by () in the first two lines, so that it’ll work with command line arguments in quotation marks 2. Replaced deltree with rmdir, since deltree is unknown at least in Windows XP and later 3. Also replaced the del command, which left an empty $PATEMP$ directory with rmdir 4. Changed $PATEMP$ to “%TEMP%$PATEMP$.%time::=%”, so that no write privileges are needed in the current directory as the users Temp directory is used and that more operations will work simultaneous, as long as they are not started at the very same time. 5. Changed %n to “%~n” to allow parameters with spaces and quotation marks if (%1)==() goto help if (%2)==() goto help SET PATMPDIR=%TEMP%\$PATEMP$.%time::=% if exist "%PATMPDIR%" rmdir /s /q "%PATMPDIR%" mkdir "%PATMPDIR%" paext -e -d -p"%PATMPDIR%" "%~1" echo. pacomp -a -r -p -w "%~2" "%PATMPDIR%\*.*" echo. rmdir /s /q "%PATMPDIR%" SET PATMPDIR=
    Profile Details
    B
    Why cant i edit my profile details? in my account
    Pacl 8.0
    PACL 8.0. What new features do you guys want from it? Current list for 8.0 RAR 5.x support. Latest ZIP/ZIPX engine with even better performance. Updated rest of engines with latest support for all file formats. Possibly: New PAF format testing. Other things like better logs or what else do we need?
    How to encrypt file names?
    Is it possible to encrypt file names as well as archive itself using pacl? I know you can do this using Power Archiver but not sure about pacl.
    Problem with large, spanned, encrypted, 7z archive.
    B
    I spent many hours trying to figure out how to use PACOMP to add about 50 Gb to a spanned 7z archive with AES256 encryption, and have yet to be successful. I’ve tried every combination of switches I can think of, with no success. Can someone offer a combination of switches that is known to work for this kind of task? All I have been able to make is a set of spanned files that PA cannot open.
    PACOMP -fips and -e2 commands
    Hi I am trying to understand what is default encryption method for PACOMP -fips command? And what is the difference if you specify encryption method using e[0,1,2] command? Using only FIPS: pacomp -a -ssecret -fips -p stuff.bh “c:\my stuff*.*” FIPS combined with e2 pacomp -a -ssecret -fips -e2 -p stuff.bh “c:\my stuff*.*”
    How to add archive comment using pacomp
    How can I add comment to archive using pacl pacomp?
    Extracting password protected archive.
    Hi All I have archive that holds password protected, encrypted data which is created using something like this: C:\Temp\ZipTest>pacomp -a -spassword -fips -e2 archive.zip "C:\Temp\ZipTest" -x"C:\Temp\ZipTest\ReadMe.txt" Then I add regular file into that archive which is not encrypted and not password protected. “ReamMe.txt” sort of file. Using command below. C:\Temp\ZipTest>pacomp -a archive.zip "C:\Temp\ZipTest\ReadMe.txt" Now when I extract this archive using: paext -spassword -p"C:\ZipTest\Temp" archive.zip Everything extracts correctly except for ReadMe.txt file. File is present but content is empty. I get following error: extracting: ReadMe.txt --> CRC ERROR! [100%] How can I extract archive without corruption ReadMe.txt file?
    Archive based on age
    O
    Does PA (preferably the CL version) have the facility to archive files based on an age? (I want to be able to move a quantity of files out of a folder and into an archive if (and only if) they’re over 35 days old. I have an ancient copy of ARJ that can do this (via the -odb switch) but I’d like to use PA, and can’t work out if it’s possible.
    Pacomp.vbs preserve the folder structure
    G
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    i have make file by powerarchiver 2011 with password put icant unzip it becouse i forget my password pls tell me what ido ineed unzip file
    PACL 9.0 Beta 2
    24 Posts 4 Posters 50.2k Views 4 Watching
      Version:
      PACL 9.00 Beta 2
      • Updated to PowerArchiver 2017 engine
      • Fully unicode interface
      • RAR v5 (v4) support
      • PAE2 support
      Download:
      PA Team
      ConeXware, Inc.
      • Brian GregoryB Offline
        Brian Gregory Alpha Testers
        Discrepancy (v8 vs v9) with new lines in output:
        C:>\PACL.v8\pacomp -a junk.7z *
        PowerArchiver Command Line (PACL) Unicode Version 8.00 [Dec 21 2015]
        Copyright© 1998-2015 ConeXware, Inc. All Rights Reserved. Registered Version
        This product is licensed to: Brian Gregory
        Archive Compression Utility – ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
        Internet: http://www.powerarchiver.com Email: support@conexware.com
        Archive: C:\junk.7z
        preparing to compress…
        adding: 595356.txt --> Done. [0%]
        adding: bin.7z --> Done. [0%]
        adding: curl.txt --> Done. [5%]
        adding: DEBUG.TXT --> Done. [7%]
        adding: FDCOM.ICO --> Done. [9%]
        adding: GEARDIFx_install.log --> Done. [9%]
        adding: GEARDIFx_uninstall.log --> Done. [9%]
        adding: HaxLogs.txt --> Done. [9%]
        adding: hcwclear.txt --> Done. [37%]
        adding: hcwDriverInstall.txt --> Done. [40%]
        adding: Iconshock-Real-Vista-Mobile-Android-platform.ico --> Done. [45%]
        adding: junk.7z --> Done. [66%]
        adding: junk.zip --> Done. [78%]
        adding: log.txt --> Done. [78%]
        adding: mplabxdrvrinstall.20160220 --> Done. [78%]
        adding: mplabxdrvrinstall.20160222 --> Done. [78%]
        adding: mplabxdrvrinstall.20160311 --> Done. [78%]
        adding: mplabxdrvrinstall.20160519 --> Done. [78%]
        adding: mplabxdrvrinstall.20160626 --> Done. [78%]
        adding: mplabxdrvrinstall.20160912 --> Done. [78%]
        adding: pnp.txt --> Done. [78%]
        adding: RHDSetup.log --> Done. [79%]
        adding: sda-0.log.0 --> Done. [79%]
        adding: sda-0.log.1 --> Done. [79%]
        adding: sda-0.log.2 --> Done. [81%]
        adding: smartctl.txt --> Done. [83%]
        adding: SxsTrace.etl --> Done. [93%]
        adding: SxsTrace.txt --> Done. [95%]
        adding: TBSVHID.log --> Done. [96%]
        adding: vulkaninfo.txt --> Done. [96%]
        adding: wifi.log --> Done. [99%]
        adding: win7.txt --> Done. [99%]
        adding: WMC default zoom.reg --> Done. [99%]
        adding: WMC sensible zoom.reg --> Done. [99%]
        All OK
        C:>\PACL.v9\pacomp -a junk.7z *
        PowerArchiver Command Line x64 (PACL64) Unicode Version 9.00b [Jan 20 2017]
        Copyright© 1998-2016 ConeXware, Inc. All Rights Reserved. Registered Version
        Archive Compression Utility – PA,ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
        Archive: C:\junk.7z
        adding: 595356.txt adding: curl.txt adding: DEBUG.TXT adding: FDCOM.ICO adding: GEARDIFx_install.log adding: GEARDI
        Fx_uninstall.log adding: HaxLogs.txt adding: hcwclear.txt adding: hcwDriverInstall.txt adding: Iconshock-Real-Vista-Mobi
        le-Android-platform.ico adding: junk.7z adding: junk.zip adding: log.txt adding: mplabxdrvrinstall.20160220 adding: m
        plabxdrvrinstall.20160222 adding: mplabxdrvrinstall.20160311 adding: mplabxdrvrinstall.20160519 adding: mplabxdrvrinstall.2
        0160626 adding: mplabxdrvrinstall.20160912 adding: pnp.txt adding: RHDSetup.log adding: smartctl.txt adding: SxsTrace
        .etl adding: SxsTrace.txt adding: TBSVHID.log adding: vulkaninfo.txt adding: wifi.log adding: win7.txt adding: WMC
        default zoom.reg adding: WMC sensible zoom.reg
        All OK
        C:>
          spwolf conexware @Brian Gregory
          @Brian-Gregory it seems you have older version, it should be:
          PowerArchiver Command Line x64 (PACL64) Unicode Version 9.00b [Mar 27 2017]
          Copyright© 1998-2017 ConeXware, Inc. All Rights Reserved. Shareware Version
          Archive Compression Utility – PA,ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZ2,XZ,LZMA
          Brian GregoryB 1 Reply Last reply Reply Quote 0
            Brian Gregory Alpha Testers @spwolf
            @spwolf Must be your CDN again :-(
            I’m still downloading the same file now.
            Please double check at your end.
              @Brian-Gregory said in PACL 9.0 Beta 2:
              ah, ivan left old pacomp.exe… use pacomp64.exe :)
                @spwolf Okay I deleted the old PACOMP.EXE and I put hard link called PACOMP.EXE to PACOMP64.EXE and similar for PAEXT (so my old batch files work).
                I still don’t get each file added on it’s own line like in v8.
                  @Brian-Gregory can you please remind me what OS again? I cant reproduce it here, looks fine… thank you!
                    @spwolf 64 bit Windows 7.
                    • BigMikeB Offline
                      BigMike
                      Your provided paconv.bat still throws errors and doesn’t work as you intend, since “deltree” is unknown on any modern Windows operating system. Also, there’s no “paext” command anymore. There are some other problems, too.
                      Please consider adding my changes from this post for PACL 8
                      1 Reply Last reply Reply Quote 3
                      • BigMikeB Offline
                        BigMike
                        There are various other problems executing the programs:
                        paclreg.exe reports it’s version 8.0
                        pacomp.exe is x64 and can’t be executed on a x86 OS
                        pacrypt.exe reports it’s version 8.0
                        paencode.exe reports it’s version 8.0
                        pafix.exe reports it’s version 8.0
                        paspan.exe reports it’s version 8.0
                        paclreg.exe registers only the “old” files, so the …32.exe and …64.exe show the shareware notice.
                        I’ve downloaded this file:
                        D 1 Reply Last reply Reply Quote 4
                          Darth Gizka @BigMike
                          @bigmike There have not been any updates so far, which suggests that the powers that be chose to ignore the problem instead of spending the 30 programmer seconds needed for fixing it.
                          However, if you compare one of the registered EXE files with an unregistered copy then you’ll see that the process of ‘registration’ for an EXE file is quite a simple one. Applying a similar change to paext32.exe or paext64.exe (using a hex editor or copy /b at the command prompt) yields the desired effect.
                          An alternative approach would be temporarily renaming ‘forgotten’ EXE files like paext32.exe to one of the names hard-coded into paclreg.exe (paext.exe, pacomp.exe, pafix.exe, paspan.exe, paencode.exe, pacrypt.exe) and renaming them back after the registration.
                          For batch files there is yet another option, one which doesn’t require changing any executables at all. Simply pipe a newline into the command in order to acknowledge the ‘unregistered version’ prompt. E.g. instead of
                          paext32 bla bla
                          use
                          echo.|paext32 bla bla
                          spwolfS 1 Reply Last reply Reply Quote 1
                            spwolf conexware @Darth Gizka
                            @darth-gizka There is now a new update:
                            https://www.powerarchiver.com/2018/01/18/powerarchiver-command-line-pacl-9-0-beta-3-is-out/
                            Check it out. Thanks!
                              @spwolf said in PACL 9.0 Beta 2:
                              Why has -p “store relative path” been removed?
                              spwolfS 3 Replies Last reply Reply Quote 0
                                @brian-gregory said in PACL 9.0 Beta 2:
                                it is default option now, but it should not have been removed since that will mess up existing scripts. thanks.
                                  idea was to automatically use -p when -r is used to have one less switch for newbies. So this will be corrected in next update.
                                  • BigMikeB Offline
                                    BigMike
                                    Signed all executables – All executables and dlls are signed with our standard authenticode to make them work better with various AV software where PowerArchiver is already whitelisted.
                                    Sorry, but as you modify the executables in the registration process, you invalidate the signature. Ok, it seems, at least, that the signature is removed completely, but it’s probably not helpful for the file rating to have signed and unsigned executables for the same version?
                                    paconv.bat still doesn’t work at all, as deltree, pacomp and paext (two of them of the very same product) are unknown.
                                    PACRYPT.exe
                                    PAENCODE.exe
                                    PAFIX.exe
                                    PASPAN.exe
                                    still report to be version 8.00
                                      spwolf conexware @BigMike
                                      @bigmike it will help a little bit during installation and initial copying, but thats the only proper way to have it done. PACL does not have issue with false positives though and having patched files companies can simply copy over is much easier than having to register it somehow else.
                                        Updated 9.00 Beta 3:
                                        https://powerarchiver.cachefly.net/2018/pacl900-180119.exe
                                        It returns -p -r to previous behaviour and also drastically improves performance when scanning folders with large number of files (100k, etc). There was an issue there where it was calculating relative path when it did not need to so it took long time… basically now it takes 5-6s and before it would be 200s.
                                          I’d like the option to return to the old output:
                                          Copyright(c) 1998-2015 ConeXware, Inc.  All Rights Reserved. Registered Version
                                          Archive Compression Utility -- ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
                                          Archive: J:\Synced Documents\BC\BC.7z
                                            preparing to compress...
                                            adding: BC201508.pdf   --> Done. [0%]
                                            adding: BC201509.pdf   --> Done. [0%]
                                            adding: BC201510.pdf   --> Done. [7%]
                                            adding: BC201511.pdf   --> Done. [15%]
                                            adding: BC201512.pdf   --> Done. [22%]
                                            adding: BC201601.pdf   --> Done. [25%]
                                            adding: BC201602.pdf   --> Done. [27%]
                                            adding: BC201603.pdf   --> Done. [31%]
                                            adding: BC201604.pdf   --> Done. [33%]
                                            adding: BC201605.pdf   --> Done. [36%]
                                            adding: BC201606.pdf   --> Done. [38%]
                                            adding: BC201607.pdf   --> Done. [41%]
                                            adding: BC201608.pdf   --> Done. [45%]
                                            adding: BC201609.pdf   --> Done. [47%]
                                            adding: BC201609Y.pdf   --> Done. [50%]
                                            adding: BC201609Z.pdf   --> Done. [51%]
                                            adding: BC201610.pdf   --> Done. [53%]
                                            adding: BC201611.pdf   --> Done. [57%]
                                            adding: BC201612.pdf   --> Done. [60%]
                                            adding: BC201701.pdf   --> Done. [62%]
                                            adding: BC201702.pdf   --> Done. [65%]
                                            adding: BC201703.pdf   --> Done. [67%]
                                            adding: BC201704.pdf   --> Done. [70%]
                                            adding: BC201705.pdf   --> Done. [72%]
                                            adding: BC201706.pdf   --> Done. [76%]
                                            adding: BC201707.pdf   --> Done. [78%]
                                            adding: BC201708.pdf   --> Done. [81%]
                                            adding: BC201709.pdf   --> Done. [83%]
                                            adding: BC201709Y.pdf   --> Done. [86%]
                                            adding: BC201709Z.pdf   --> Done. [88%]
                                            adding: BC201710.PDF   --> Done. [91%]
                                            adding: BC201711.pdf   --> Done. [93%]
                                            adding: BC201712.pdf   --> Done. [96%]
                                            adding: BC201801.pdf   --> Done. [98%]
                                          All OK
                                          rather than the new
                                          PowerArchiver Command Line x64 (PACL64) Unicode Version 9.00b      [Jan 19 2018]
                                          Copyright(c) 1998-2018 ConeXware, Inc.  All Rights Reserved. Registered Version
                                          Archive Compression Utility -- PA,ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
                                            compressing...
                                            total progress: 11%
                                            total progress: 22%
                                            total progress: 33%
                                            total progress: 45%
                                            total progress: 56%
                                            total progress: 67%
                                            total progress: 78%
                                            total progress: 90%
                                          All OK
                                          where you aren’t told which files were added
                                            @brian-gregory problem for 7z and PA formats is when multi-threading is enabled, current file progress could cause issues due to it reporting from multiple different threads to the main thread. So
                                            Previously we simply did not have MT support for 7z due to this issue.
