    Faster startup and close times in PA 2017
    Scheduled Pinned Locked Moved Solved Wishlist
    31 Posts 4 Posters 36.0k Views 2 Watching
      spwolf conexware @nikkho
      @nikkho thanks for letting me know.
      • AluminumHasteA Offline
        AluminumHaste
        @spwolf for the image loading, since streaming data off HDD can be slow compared to handling images in memory, would combining all the images into an image atlas (one large image) and mapping the pixel locations to things instead be faster on startup?
        Similar to how minecraft stores it’s game textures in one large image file. Then you’re only loading 1 image file off the hard drive instead off hundreds.
          spwolf conexware @AluminumHaste
          @aluminumhaste said in Faster startup and close times in PA 2017:
          so how come you dont have PA 2018 preview already? Should I send it over. Its fast. Faast!
          AluminumHasteA 1 Reply Last reply Reply Quote 0
            AluminumHaste @spwolf
            @spwolf I used to try the Alpha a few years ago, don’t know why I stopped. Sure, glad to try it out.
              AluminumHaste
              Loading testing completed:
              Powerarchiver 2017
              1.38 sec
              1.46 sec
              1.35 sec
              Powerarchiver 2018 - Alpha
              0.53 sec
              0.63 sec
              0.60 sec
              Closing has always been fast on my computer, 2018 is almost instant.
              spwolfS 1 Reply Last reply Reply Quote 2
                @aluminumhaste thats pretty fast for 2017 too… when memory gets more fragmented during days of use, 2018 will go to 0.8s while 2017 will do something like 2.3-2.5s. At least from my experience.
                Then if disk is doing something else in the background, we could have 2018 doing 1.3-1.5s while 2017 does 3.5-4s on same computer and ssd.
                thanks for testing, how does it feel?
                  AluminumHaste
                  Snappy, fast, quick.
                    AluminumHaste
                    I tried PA 2017 portable, on work computer takes about 5 seconds to open
                      should be less than 2s in PA 2018… i dont think Portable is any slower, it is just different computer and possibly memory fragmentation after long running.
                        AluminumHaste
                        This is a work computer so yeah, also was loading that off of a USB flashdrive.
                          Check latest PA 2018 build, and compare the speeds to 2017, 2016, etc.
                          New version: PowerArchiver 2018 18.00.23 - BETA 1
                          Download: http://dl.powerarchiver.com/2018/powarc180023.exe
                          N 1 Reply Last reply Reply Quote 1
                          • N Offline
                            nikkho Alpha Testers @spwolf
                            @spwolf Indeed much faster!
