    Explorer.exe Crash on right click
    26 Posts 3 Posters 24.7k Views
      it seems to be fine here…
      Brian GregoryB 1 Reply Last reply Reply Quote 0
      • Brian GregoryB Offline
        Brian Gregory Alpha Testers @spwolf
        Yes, I agree, it must be something else.
        Sorry.
          Brian Gregory Alpha Testers @Brian Gregory
          CORRECTION:
          I’ve been experimenting with SysInternals autoruns.exe disabling things to see what cures my problem and disabling this:
          HKLM\SOFTWARE\Classes\Folder\ShellEx\ContextMenuHandlers\PowerArchiver64
          which refers indirectly to
          “c:\program files (x86)\powerarchiver\pashlext64.dll”
          fixes the crashing problem when right clicking junctions, at the expense (obviously) of losing the PA right click on folder operations.
          Next I’ll try rearranging my PA context menu items to see if that fixes it.
            No, fiddling subtly with PA’s right click options makes no difference.
              try this:
              1. save you PA registry via Options> Export settings.
              2. Reset your PA options by using set defaults
              If it still happens, try disabling every other shell extension but enabling PA and lets see if it happens then.
              We have to find a way to reproduce it here.
              What exactly are you clicking on? I tried C:\Documents and Settings as well as C:\users All Users or Default user and it all seems fine, and i have tons of various different PA shell extensions on.
              Also - always use latest PA - which is 14.02.
              Brian GregoryB 2 Replies Last reply Reply Quote 0
                I think you probably need more than one junction for it to fail.
                Please try this:
                Download JUNCTION from here:
                http://technet.microsoft.com/en-gb/sysinternals/bb896768.aspx
                Extract junction.exe from the junction.zip you downloaded in to C:
                (or the root of any other local drive or partition)
                open command prompt and cd to the root of your chosen drive, run junction, and agree to EULA.
                Then do:
                md test-dir
                junction junc1 test-dir
                junction junction-test test-dir
                Then open an explorer window and right click junc1 several times.
                You don’t need to choose anything from the resulting menu if it appears.
                I find the first right click produces a menu with slightly garbled PowerArchiver parts in it and then the second time explorer crashes.
                Afterwards you can clean up by doing this at the command prompt:
                junction junc1 /d
                junction junction-test /d
                rd test-dir
                del junction.exe
                or just delete the created items using explorer
                Afterthought:
                If you use C:\ you may need to run the command prompt as Administrator.
                  Why isn’t this showing up in PatchBeam, I have asked it to show me BETA versions.
                    i tried it with 3 junctions and was able to reproduce it… thanks!
                      Try this latest release please, it is up on the PatchBeam… let us know how it works :-)
                        It works great.
                        Thanks.
                          Hello it’s me again.
                          I’ve found ANOTHER case where right clicking a junction still crashes explorer due to PowerArchiver. (Using PowerArchiver 14.02.03).
                          Please try this:
                          Then do:
                          md test-dir
                          rd test-dir
                          Then open an explorer window and right click junc1.
                          Explorer should crash.
                          (If it doesn’t maybe you need two junctions in the root).
                          junction junc1 /d
                          del junction.exe
                          Thanks in advance.
                            Hello?
                              We got it, we will check it out for next release, as usual :-)
                                Is this (Explorer crash when right clicking a junction pointing to non existent folder) supposed to be fixed in 14.02.05 ?
                                Either it isn’t fixed for me or, as often happens, Powerarchiver is proving difficult to update to the latest version without some old files getting left in use.
                                  nope, it will come in update to come :-)
                                    When exactly?
                                    Am I only allowed one bug fix or something?
                                    Is somebody reporting more than one bug regarded by you as a trouble maker?
                                      of course not, we had some other things to finish up first…
                                        Brian,
                                        do you have ZTE installed as well, or just PA?
                                          Brian,
                                          Just PA and PACL.
                                            This should be fixed in latest release:
                                            http://powerarchiver.com/test/release13/powarc140503int.exe
                                            Please let us know and thanks!
