    PA 14.00.18 load time
    44 Posts 8 Posters 24.2k Views
      Yes, thanks Peter!
      P 1 Reply Last reply Reply Quote 0
      • P Offline
        PeterM @Mili
        Hope this solves some issues relating to slow startup (first time start)
        for some as it fixed my problem. It was so annoying at times clicking to open
        a file and it would just hang. By that time you already clicked on it 2 to 3 times which then ran multiple instances of PA.
        Peter
          spwolf conexware @PeterM
          @PeterM:
          Peter
          we will keep emailing them to add new version to their whitelist so you dont have to… it is very annoying, most people wont know to do 11. steps required.
            drteeth
            I have to say no p[erformance issues with ESET other than this one. Computer just as fast, if not moreso than Kaspersky - left Kaspersky as their mods arrogant and power mad in the extreme as well as being often wrong.
              spwolf conexware @drteeth
              @drteeth:
              I have to say no p[erformance issues with ESET other than this one. Computer just as fast, if not moreso than Kaspersky - left Kaspersky as their mods arrogant and power mad in the extreme as well as being often wrong.[/QUOTE]
              i am so happy I dont use any :-).
              For me NOD32 was pretty intrusive (compared to nothing)… I have had BD 2013 for testing, as we sell it, and it wasnt as intrusive, but as I am my own master on my own computer, i dont use any AVs in general (i dont download exe’s from internet, except major applications).
              I guess it is not easy for them to fight off all the evil :-)
                drteeth
                OT: I wish I had the cajones to run without AV. I am very naughty on the internet and do not get much of a peep from my AVs. I am much more worried about rogue web sites that infect PCs. Infected exe’s are sooo yesterday LOL.
                Both KAV and ESET do not slow down the machine at all, but KAV would not accept exceptions without nagging about them. No probs with ESET. I do not like the AVs whose interfaces have gaudy colours and do not allow detailed configuration - i.e. they are designed for noobs.
                  we got access to their whitelist ftp, so we will have to upload each new release there and it will be auto-magically whitelisted by ESET.
                  So let us know if you continue noticing anything :-)
                    drteeth
                    I am still having to list it in the exclusions. I have PA 14.00.20 and had not run it at all since booting earlier. I removed the exclusion from ESET and had to wait approx 15-20 secs for the window to appear. Has this latest version been (supposedly) whitelisted yet?
                      @drteeth:
                      it probably takes them a little bit, like a day, we uploaded 2013 b4 and 2012 official today.
                        do let us know if this changes in next day or two, as it should. I uninstalled it myself.
                          drteeth
                          Seems to be okay today. I have deleted the exclusion and will monitor the situation.
                          Regards
                            @drteeth:
                            Regards
                            ok, please do. thanks!
                            R 1 Reply Last reply Reply Quote 0
                            • R Offline
                              robertmc8 @spwolf
                              I’m having load time issues on windows 8.1 preview let you know takes about 45 secs to load. I’m on OCZ vertex 3 90gig with 16gig of ram.
                                spwolf conexware @robertmc8
                                @robertmc8:
                                thats pretty crazy… any antivirus?
                                • R Offline
                                  robertmc8 @spwolf
                                  Nope It’s not Norton 360 no beta I was even testing new norton 360 v21 it still did that. I used Norton 360 all the time. There was no issue with 2012 version. I’m on AMD system.
                                  • R Offline
                                    robertmc8
                                    I just test with windows 7 on my backup 1 TB hard drive normal it loads fine. Really quick. Even with norton 360 installed there also. spwolf’s if you want I can make recording video of the loading issue on my desktop? Sometime this week.
                                      @robertmc8:
                                      not sure if i understood - do you have Norton installed or not?
                                      There is no reason for PA to load that slow… I have Windows 8.1 myself and it is exactly the same as Windows 8 when it comes to startup. It has to be something blocking it like Norton or ESET in this thread.
                                      • R Offline
                                        robertmc8 @spwolf
                                        Yes Norton is install same issue also without install. It just loads slow. You on ssd?
                                          @robertmc8:
                                          yeah but it loads in 1.8s total… probably a lot slower computer than yours as it is laptop… i will check with 360.
                                          • R Offline
                                            robertmc8
                                            My pc specs with turbo up to 3.8ghz on air :). http://valid.canardpc.com/2891262
