    Auto detection if PA should use "largeZIP" or not
    5 Posts 3 Posters 7.9k Views
    • K Offline
      klumy
      PA should support auto detection if it should use “make largeZIP 4Gb” option or not.
      So the use needn’t set this setting by himself
        Did you see this thread
        http://www.powerarchiver.com/forums/showthread.php?t=405
        With the “make large” option checked (active), PA will auto detect!
        The flag is not activated by default for “backward compatibility”.
        That will probably change, soon ?
          spwolf conexware @TBGBe
          @TBGBe:
          For 9.5 that option will most likely be turned on at all times and removed from option list…
          K 1 Reply Last reply Reply Quote 0
          • K Offline
            klumy @spwolf
            great
            this will improve the working with PA
              spwolf conexware @klumy
              you can leave it on yourself at all times and it will work the same… It is already enabled in compress to filename.zip in shell extensions.
              thanks,
