    Cloud: Autorize SkyDrive doesn't work
    27 Posts 4 Posters 14.4k Views
    • guidoG Offline
      guido
      After pressing OK to enable the permissions for PA (Which are a lot, can yo u explain why?)
      The form just stays blanco. And none responsive.
      Windows 11 Pro ENU x64
      Intel Core I7
      32 GB RAM
      • guidoG Offline
        guido
        I guess it took so long to create the filelist.
        Intel Core I7
        32 GB RAM
          it is hard to understand whats going on :-)
          I guess i need to try it out myself.
            you mean why all the access rules? dunno, thats how it works… it is only your PowerArchiver though, not some web application, but your local PA.
              so how many files do you have there? was it faster 2nd time? was it non responsive first time? I got nothing inside right now, so i will try to reproduce.
                Ironically, I was just going to make a post about this.
                Skydrive seems from the start go unstable.
                The 1st this is the Authorize Dialog hangs once you have logged in and there is now way other that to exit the application via task manager.
                Then there seems to be a delay or hang on most of the files and folders.
                Attachment Cloud and Dropbox both worked without issue and are quick.
                  Authorize is an IE window that access’s the SkyDrive website… once you authorize it, it saves the token on your computer… but thats all up to SkyDrive I believe… we will see more about it.
                  RJWaringR 1 Reply Last reply Reply Quote 0
                    amh209
                    Trying to get Google Drive to work. I clicked on it and it took a minute, opened a window, then asked for email and password.
                    Entered the info, then the screen updated and wanted me to accept the terms, which I did. It takes a few seconds and then it gives an error unable to load the page.
                      spwolf conexware @amh209
                      @amh209:
                      yeah, i just checked, it is all done via Google pages - it doesnt have anything to do with PA itself - it doesnt go to our site, nor anything is stored on our site… it is all done by google.com and whatever the name of skydrive itself is.
                      Now I wonder if the problems people are having are due to crappy IE, because it is IE that opens up as it is always installed on the system. But there is nothing we can do about that though.
                      It does seem that IE11 they have in 8.1 I am using is finally usable… 10 was horrible on my computer, didnt want to load anything properly.
                      • guidoG Offline
                        guido
                        FYI, my 25GB SkyDrive is almost Full.
                        Intel Core I7
                        32 GB RAM
                        • guidoG Offline
                          guido
                          Second time is just as slow.
                          Intel Core I7
                          32 GB RAM
                            a lot of files - how many files are there and how long it takes? We can at least make it more responsive… i will upload a lot of small files to mine to test
                              we were able to improve the load times for the file list, lets see by how much.
                                ok, so 15s for .20 vs 28s for .18, for logging/loading filelist Skydrive. So abou 2x faster for newer version.
                                This is for +1000 files or so… we also added some “progress” messages and little bit more responsive, also fixed total upload progress bar.
                                It is not perfect yet, but it is better.
                                • guidoG Offline
                                  guido
                                  it takes almost 5 minutes…
                                  Intel Core I7
                                  32 GB RAM
                                    so it will take 1/2 now, at least :P
                                    we could do caching… we will see… (in the future)
                                    guidoG 1 Reply Last reply Reply Quote 0
                                    • guidoG Offline
                                      guido @spwolf
                                      well this is already 1/2 :)
                                      Intel Core I7
                                      32 GB RAM
                                        what version are you trying?
                                        • guidoG Offline
                                          guido
                                          Intel Core I7
                                          32 GB RAM
