    Plugin Disbaled
    I
    I have 3 users so far (I think since outlook 365 updated) that have found PAOP disabled in outlook… for slowness and issues ?? Ian
    PowerArchiver Outlook Plug-In don't works correctly
    Hi. I have here with the PowerArchiver Outlook Plug-In 3.04 the following Problem. When I wanted to go to the options in outlkook 2007 and than go to the Register powerarchiver, then Outlook seems for a short time to be broken, but than the Register powerarchiver opens in a Windows which is as big as the Monitor. In this Windows I can not make any changes or so. I can only close the windows with alt + F4, but than the whole Option Windows is closed. Here is a Screen with Outlook 2007and PowerArchiver Outlook Plug-In 2.4 [URL=http://www.bilder-upload.eu/show.php?file=4c9f62-1501486418.jpg][IMG]http://www.bilder-upload.eu/thumb/4c9f62-1501486418.jpg[/IMG][/URL] This Screens shows Outlook 2007 with the PowerArchiver for Office Plug-In 3.04 [URL=http://www.bilder-upload.eu/show.php?file=5632b5-1501486482.jpg][IMG]http://www.bilder-upload.eu/thumb/5632b5-1501486482.jpg[/IMG][/URL] So at the Moment I Need to go back to the Plug in 2.4 because this version works good for me. MDuss
    Compression when I have profiles
    If I choose compress with options, and then try to create my own filename for an archive, I cannot do it. I have to choose one of your profiles from the shell, compress it, and then rename it to what I want. One of the many reasons I want to be able to add my profiles to the shell.
    Assume . . . but checking
    I have been unable to use the AC for a day now. I assume it is just a downed server. If not, then something is amiss on my system, and I need to figure out what.
    Oddity
    Very odd. Right now I can upload files to AC via ZTE, but I cannot upload them directly from within PACLOUD.
    ZTE won't work
    . . . on either the 64 or 32 bit machines. I keep getting an authentication error. Adding my PW does not help. But from within PA, I can get to my AC. I am guessing that ZTE 2013 doesn’t play well with the upgraded (upgrading) AC server. BTW. It also does not work the way it should within Outlook. the dialogue opens, but it does not compress it and does not send it to the attachment cloud.
    Coming soon?
    I noticed that when the user opens the AC and right clicks on a file, there is a grayed out option: “Copy to Clipboard direct download link.” Will this be active in the next update? If we plop this link in an email, will it be governed by the settings in ZTE – e.g., how long the recipient has to download it, whether it notifies us when it is downloaded, etc.? And will the next version have the correct version number in the about screen? I do not it confusing when the number and revision date are incorrect. Any chance you will be adding a delete option? If not, will there be a column that shows the user if the file is still active (can still be downloaded)?
    Notifcation is not working
    The notification of file downloads via the Attachment Cloud are no longer working in the last couple of alpha releases. Not sure if it still works in 13.03. Perhaps when you fix this, you can also get it to send simple one acknowledgement, rather than two.
    Need command prompt code for zip file.
    V
    Hi All, I am working windows machine. I need code for ziping file using powerarchiver in command prompt. For unzip i will use the below code. C:\Projects\Wrigley\POWERARC.EXE -e “C:\Documents and Settings\Administrator\Desktop\wa\ka6timwh.zip” "C:\Documents and Settings\Administrator\Desktop\wa" But i don’t have zip code. can you please provide me. Thanks venkat
    ZTE - 1.00.23 Beta - Register Tab/Box
    Hi Team, I noticed that ZTE Requires the user to type in their details via the Configuration page. Now, this kinda looks off to me as once the user registers their details its a tab that just sits there. Could you either Duplicate the Pop up box used in PowerArchiver? Or move the Register section into the “About” page at the mid bottom page. That way you are keeping all Data on the version, the user and the conditions on one tab. And if that works and looks neat you could roll that over to PowerArchiver and remove it’s pop up window.
    ZTE - 1.00.23 Beta - PA FTP
    Team, I understand that ZTE ideally is to be kept separate from PA. But due to some of the features Utilizing the same as PowerArchiver’s Application such as FTP. It would be good if the user could interact with those inside either applications. For example for FTP users may have PA Profiles already setup and wish to use them or edit them slightly, So what would be create is two tick boxs in the ZTE Configuration screen under FTP (Pro) -> Profiles; Import PowerArchiver’s FTP Profiles Sync PowerAchiever’s FTP Profiles The user can only choose one option and when they do the other box greys out. Import An exact copy of PA’s FTP Profiles into ZTE at that time yet enables the user to change them without it modifying PAs profile. Sync Basically it adjusts ZTE’s FTP Profile to use PowerArchiver’s FTP Profile. Any changes in either application is synced between them. This would be very handy for users like me, who can use either or and don’t want to be duplicating settings all the time.
    ZTE - 1.00.23 Beta - Tabbing
    Hi Team, Within the Zip To Email 2013 Configuration Page when tabbing there is little to no order. Could you index those fields, boxes and buttons in order per page. Cheers
    Hi Guys, I have just registered my Copy of ZTE withing Office 2010 (No Service Pack) on Windows XP Pro SP3. The product registered without a problem. But one thing i have noticed is the Register Icon that appears within the Ribbon still appears. I know in VBA you can do this so can you set it up that when the product is registered successfully you remove that “Register” icon? Thank you,
    Question and several issues
    I cannot get the attachment cloud to work. It does not send me an verification email. And I doing something wrong? Two glitches with ZTE (when I use my own server): encryption doesn’t work. I have to use plain FTP. if the file name has any spaces in it (and many of mine do), the hyperlink does not work. ZTE sets up a hyperlink only to the end of the first word in the filename; so it doesn’t really work unless I truncate the name before sending.
    Something odd
    No major disaster, but something odd. I decided to remove ZTE and go back to PAOP. It had one odd consequence. It fouled up my FTP settings which I could fix only by uninstalling and then reinstalled PA. It may be that there is is minor tweak that would solve this problem. BTW, I had exactly the same thing happen on two different machines – both running Win 7, but one running 32 bit and one 64.
    ZTE - 10020B1 - BUG [Folders]
    Hi Guys, This bug was found on my new work laptop Specs Windows XP SP3 Office 2010 Reference the Folders temp location. The button that typically opens a location window doesnt.
    Upgrade deletes all the previous settings
    No error when installing .14 this time either. I did do a upgrade from .13 to .14 and I noticed it wiped all my settings so not sure if thats on purpose at the moment during testing or not.
    PatchBeam seems broken in both ZTE and PA
    Not sure what its doing, but if I try and update PA or ZTE using PatchBeam it doesnt do anything. Do a repair install on PA you think? Wasnt sure if ZTE broke PA’s PatchBeam or not.
    Paop
    Will you all still be supporting PAOP, or will everything eventually have to move to ZTE?
    Zte 1.00.17 alpha testing!!!
    Hello dear friends/users. This is the start of Alpha testing for ZTE - Zip to Email. What is ZTE? ZTE is standalone application designed to help you email attachments better. It is PAOP on steroids. How can ZTE be used? Shell Extensions - shell extensions will let you compress/encrypt and email any group of files. Outlook Plugin - Outlook plugin will automatically compress/encrypt any attachments sent via Outlook, based on your set preferences. What are the features? Compress files to ZIP, ZIPX, 7zip, CAB, TAR.GZ and SFX formats. Encrypt files with ZIP AES with FIPS 140-2 certification. Extensive filter support to exclude attachments based on file size or file extension. Extra Features Integration with FTP/HTTP server. This lets you setup your own FTP server to upload attachments to and ZTE will insert HTTP link to it, so you have your own “cloud” setup. Integration with AttachmentCloud. Our own cloud service, upcoming. Right now you can setup account via installation and use it, Website is not ready yet. Zip to Email (ZTE) is completely standalone and does not require PowerArchiver. It is best if you uninstall PAOP first if you are using it right now. [image: attachment_t_5437_0_ztenewemail.png]
    ZTE 'shell' images
    8 Posts 3 Posters 10.4k Views
      Strange how I missed this but I’ve noticed even though I’ve got the option to ‘use images beside menus items’ ticked it fails to do so as shown in the screenshot attached.
      • ivanI Offline
        ivan conexware
        Mike, is this on Windows 32-bit. We detected the issue on Windows x86, not on Windows x64 as you stated in your footer…
          this is on Windows 7 Ultimate x64 Ivan
            spwolf conexware @ivan
            @ivan:
            i dont have them on x64 either… is this someone from upstairs telling us we need ZTE icons? :P
            • ivanI Offline
              ivan conexware
              There was an error displaying images in shell context menus, but will be fixed in next release.
              Right now it is same image as in PA, but we will make a new icon for ZTE shell.
                are there plans to integrate the Zte ‘shell’ options into the existing PA ‘shell’ options or will it continue to ‘stand alone’ ?
                • ivanI Offline
                  ivan conexware
                  Will continue to stand alone since they are independent applications (user can have PA or ZTE or PA+ZTE installed), they will have different icons and most of the options are different. We only can detect if user has PA installed before installing ZTE and disable any e-mail shell options in PA and enable those in ZTE.
                    ‘shell’ images are now displaying perfectly…many thanks guys…:)
