    pacl900b-190606.exe (PACL 9.0 Beta 5) pacomp -r not working.
    I’m trying to backup the complete contents of a directory using: pacomp64 -parcz T:\BACKUP.PA C:\STUFF The contents of subdirectories of C:\STUFF isn’t getting backed up! The sub directories are just stored as empty directories!
    When extracting 7z files extract only newer files
    B
    How do I achieve this ; show me a command line example !
    Question Regarding License
    Hello @Mili, thanks for your help in getting my PowerArchiver CommandLine license (Re: License Code Not Working / Missing) and sorry for my late reply. I do check my spam folder regularly and couldn’t find a mail from support. Also, there was no mail in my backups or any mention of it in my email logs. I have a question regarding my licenses in the hope you are able to help me: While my account lists “PowerArchiver Select - lifetime free upgrades and support for PowerArchiver Toolbox English - Count 2”, this does not apply for PACL, which was included with my purchase. My account shows only PowerArchiver Select - 12 months of upgrades and support for PowerArchiver Command Line - Single User License. Since PACL was included with PowerArchiver Toolbox, shouldn’t PACL also come with a lifetime license for 2 PCs? Thanks for your help in advance.
    PACL 9.0 Beta 2
    Version: PACL 9.00 Beta 2 What’s New since version PACL 7: Updated to PowerArchiver 2017 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support and all the various engine updates done in PA 2017. Full support for .PA format with many different options and switches. Download: http://dl.powerarchiver.com/2017/PACL900-170429.EXE Due to the support of new PA format and all the changes needed for that support, we decided to move up version number to PACL 9. This is purely cosmetical - companies who purchased PACL8, have PACL9 now added to their orders. Users who have free upgrades for PACL8, now have PACL9 added as free upgrade (Business users with active select (pro/tbx), all personal users (pro/tbx). Since we are finalizing PA 2017, we can also now spend a lot more time on PACL9. Please check your bugs, and check .PA support as well. Thank you! @Alpha-Testers PA Team ConeXware, Inc.
    The PACL does not extract files from the self-extracting archive
    Michael72M
    My OS: Windows XP Home Edition, SP3 The version number and date of the program: PowerArchiver Command Line v9.00b [Feb 23 2019] The program not extracts one self-extracting file. How to reproduce the problem Download the SFX file by link: install.exe Copy the “install.exe” file into the same location as the program is located. Go to the DOS prompt. Make your PACL location the default drive. If it is on the E drive enter the command E: and press enter. Replace “E:” with the appropriate drive letter. Enter command cd e:<path name> to go to the location where the program resides. Enter command: paext32 -o+ -p"install" "install.exe" As a result, the “install” directory will not be created and no files will be extracted. The “install.exe” file may be damaged but if you use a program such as 7-Zip or PeaZip to extract the files, the extraction process is successful. I want the PACL to also unpack such a file. This problem is very critical for me. I often come across this. I do not want to resort to using other compression program. … Michael
    PACompXX problem with file name syntax
    czip support
    would be nice to have czip support
    PACL 8.0 Beta 1
    Version: PACL 8.00 Beta 1 Whats New: Updated to PowerArchiver 2016 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support such as improved ZIPX, ISO, etc, etc, etc. Download: http://dl.powerarchiver.com/2016/pacl800b1.exe Please test it against your existing scripts and let us know. There will be some features added in future release as well as more testing. This is first release, please test. Thank you!
    pacomp-exe-has-stopped-working)
    P
    I am Having Appcrash mid problem in my Pc.
    PAConv.bat
    Hi, I’ve made changes to fix some problems with PAConv.bat: 1. Replaced the “” by () in the first two lines, so that it’ll work with command line arguments in quotation marks 2. Replaced deltree with rmdir, since deltree is unknown at least in Windows XP and later 3. Also replaced the del command, which left an empty $PATEMP$ directory with rmdir 4. Changed $PATEMP$ to “%TEMP%$PATEMP$.%time::=%”, so that no write privileges are needed in the current directory as the users Temp directory is used and that more operations will work simultaneous, as long as they are not started at the very same time. 5. Changed %n to “%~n” to allow parameters with spaces and quotation marks if (%1)==() goto help if (%2)==() goto help SET PATMPDIR=%TEMP%\$PATEMP$.%time::=% if exist "%PATMPDIR%" rmdir /s /q "%PATMPDIR%" mkdir "%PATMPDIR%" paext -e -d -p"%PATMPDIR%" "%~1" echo. pacomp -a -r -p -w "%~2" "%PATMPDIR%\*.*" echo. rmdir /s /q "%PATMPDIR%" SET PATMPDIR=
    Profile Details
    B
    Why cant i edit my profile details? in my account
    Pacl 8.0
    PACL 8.0. What new features do you guys want from it? Current list for 8.0 RAR 5.x support. Latest ZIP/ZIPX engine with even better performance. Updated rest of engines with latest support for all file formats. Possibly: New PAF format testing. Other things like better logs or what else do we need?
    How to encrypt file names?
    Is it possible to encrypt file names as well as archive itself using pacl? I know you can do this using Power Archiver but not sure about pacl.
    Problem with large, spanned, encrypted, 7z archive.
    B
    I spent many hours trying to figure out how to use PACOMP to add about 50 Gb to a spanned 7z archive with AES256 encryption, and have yet to be successful. I’ve tried every combination of switches I can think of, with no success. Can someone offer a combination of switches that is known to work for this kind of task? All I have been able to make is a set of spanned files that PA cannot open.
    PACOMP -fips and -e2 commands
    Hi I am trying to understand what is default encryption method for PACOMP -fips command? And what is the difference if you specify encryption method using e[0,1,2] command? Using only FIPS: pacomp -a -ssecret -fips -p stuff.bh “c:\my stuff*.*” FIPS combined with e2 pacomp -a -ssecret -fips -e2 -p stuff.bh “c:\my stuff*.*”
    How to add archive comment using pacomp
    How can I add comment to archive using pacl pacomp?
    Extracting password protected archive.
    Hi All I have archive that holds password protected, encrypted data which is created using something like this: C:\Temp\ZipTest>pacomp -a -spassword -fips -e2 archive.zip "C:\Temp\ZipTest" -x"C:\Temp\ZipTest\ReadMe.txt" Then I add regular file into that archive which is not encrypted and not password protected. “ReamMe.txt” sort of file. Using command below. C:\Temp\ZipTest>pacomp -a archive.zip "C:\Temp\ZipTest\ReadMe.txt" Now when I extract this archive using: paext -spassword -p"C:\ZipTest\Temp" archive.zip Everything extracts correctly except for ReadMe.txt file. File is present but content is empty. I get following error: extracting: ReadMe.txt --> CRC ERROR! [100%] How can I extract archive without corruption ReadMe.txt file?
    Archive based on age
    O
    Does PA (preferably the CL version) have the facility to archive files based on an age? (I want to be able to move a quantity of files out of a folder and into an archive if (and only if) they’re over 35 days old. I have an ancient copy of ARJ that can do this (via the -odb switch) but I’d like to use PA, and can’t work out if it’s possible.
    Pacomp.vbs preserve the folder structure
    G
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    i have make file by powerarchiver 2011 with password put icant unzip it becouse i forget my password pls tell me what ido ineed unzip file
    PACL 7.00 b1 file extension upper case problem
    6 Posts 3 Posters 11.7k Views
    • MickeM Offline
      Micke Alpha Testers
      Hi!
      I have found out something interesting in the PACL 7.00 b1 version. I haven’t tested this in PACL 6.01 yet, so I can’t tell if this only happends in PACL 7.00 b1.
      Anyway, here’s a list of files I’ve been using for tests.
      2012-02-05  16:07    <kat>          .
      2012-02-05  16:07    <kat>          ..
      2010-02-24  18:28         1***censored***077***censored***633 Amiga XP x86.pdf
      2009-12-15  22:31            73***censored***328 Deluxe Paint 4 Manual.pdf
      2012-02-05  15:12                 4 password.txt
      1997-09-08  22:52            73***censored***648 REFSCAN1.PCX
      1997-09-08  22:55            57***censored***080 REFSCAN2.PCX
      1997-09-08  22:56            36***censored***833 REFSCAN3.PCX
      1997-09-08  22:58            57***censored***612 REFSCAN4.PCX
      1997-09-08  23:00            55***censored***959 REFSCAN5.PCX
      1997-09-08  23:02            31***censored***751 REFSCAN6.PCX
      2012-02-05  15:30            54***censored***230 Test1.zip
      2012-02-05  16:12    <kat>TF
                    10 fil(er)           1***censored***518***censored***078 byte
                     3 katalog(er)  17***censored***113***censored***018***censored***368 byte ledigt
      C:\PACL_Test\Amiga></kat> </kat></kat>
      ```Pay attention to the file names REFSCAN that have the file extension in upper case (.PCX).
      I the try to create a zip archive with all the PCX files in it.
      C:\PACL_Test\Amiga>pacomp -a Test2.zip REFSCAN*.PCX
      PowerArchiver Command Line (PACL) Version 7.00 [Jan 29 2012]
      Copyright© 1998-2012 ConeXware, Inc. All Rights Reserved. Shareware Version
      Remainder: This is unregistered version of PACL. Please register at http://www.p
      owerarchiver.com
      Press <enter>to continue.
      Archive Compression Utility – ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
      Internet: http://www.powerarchiver.com Email: support@conexware.com
      Archive: C:\PACL_Test\Amiga\Test2.zip
      preparing to compress…
      *** WARNING: Nothing to add or update…
      All OK
      C:\PACL_Test\Amiga></enter>
      C:\PACL_Test\Amiga>pacomp -a Test2.zip REFSCAN*.*
      owerarchiver.com
      All OK
      C:\PACL_Test\Amiga>pacomp -a Test2.zip REFSCAN*.pcx
      owerarchiver.com
      All OK
      I then change to another folder that also had some .pcx files in it.
      2012-02-05 15:39 <kat> .
      2012-02-05 15:39 <kat>…
      2009-09-14 22:32 27censored760 3Pluto.pcx
      2009-09-14 22:32 42censored917 4Goofy.pcx
      2009-09-14 22:32 28censored119 5Donald.pcx
      2009-09-14 22:32 28censored919 6Daisy.pcx
      2012-02-05 15:39 103censored786 Test2.zip
      5 fil(er) 231censored501 byte
      2 katalog(er) 17censored113censored022censored464 byte ledigt
      C:\PACL_Test\Amiga\TF></kat> </kat>
      C:\PACL_Test\Amiga\TF>pacomp -a Test3.zip *.pcx
      owerarchiver.com
      Archive: C:\PACL_Test\Amiga\TF\Test3.zip
      adding: 3Pluto.pcx --> Done. [21%]
      adding: 4Goofy.pcx --> Done. [55%]
      adding: 5Donald.pcx --> Done. [77%]
      adding: 6Daisy.pcx --> Done. [100%]
      All OK
      C:\PACL_Test\Amiga\TF></enter>
      C:\PACL_Test\Amiga\TF>pacomp -a Test3.zip *.PCX
      owerarchiver.com
      All OK
      Now It seems logic that the program treats .pcx and .PCX as different file extensions, but if the file extension for some reason is stored in upper case, why can't the program add them to the archive?
      Kind Regards
      Micke
        thanks a lot - we will check it out… 7.0 is big rework of all engines so i expect more buggies like this to happen.
        MickeM 1 Reply Last reply Reply Quote 0
        • MickeM Offline
          Micke Alpha Testers @spwolf
          Hi!
          I have now repeated the test using PACL 6.01. First look in the folder.
          2010-09-06  07:09
          <dir>          .
          2010-09-06  07:09
          <dir>          ..
          2010-07-28  20:32
          <dir>          TF
                         8 File(s)      1***censored***463***censored***844 bytes
                         3 Dir(s)  145***censored***127***censored***018***censored***496 bytes free
          I then try to create a zip archive using PACOMP and filenames REFSCAN*.*
          C:\Programs\Test\Amiga>pacomp -a Test1.zip REFSCAN*.*
          PowerArchiver Command Line (PACL) Version 6.01 [Feb 07 2010]
          Copyright© 1999-2010 ConeXware, Inc. All Rights Reserved. Registered Version
          This product is licensed to: Micke
          Archive: C:\Programs\Test\Amiga\Test1.zip
          adding: REFSCAN1.PCX --> Done. [23%]
          adding: REFSCAN2.PCX --> Done. [41%]
          adding: REFSCAN3.PCX --> Done. [53%]
          adding: REFSCAN4.PCX --> Done. [71%]
          adding: REFSCAN5.PCX --> Done. [89%]
          adding: REFSCAN6.PCX --> Done. [100%]
          All OK
          C:\Programs\Test\Amiga>pacomp -a Test2.zip REFSCAN*.PCX
          Archive: C:\Programs\Test\Amiga\Test2.zip
          All OK
          Kind Regards
          Micke</dir>
          </dir>
          </dir>
            Thanks Micke, logged in!
              PACL 7.00 RC1 http://www.powerarchiver.com/test/alpha120/pacl700.exe
              please check it out.
              • MickeM Offline
                Micke Alpha Testers
                Tested in PACL 7.00 RC1. Files will be added correctly independent of upper or lower case of file extension.
                Bug Fixed Confirmed
                Kind Regards
                Micke
