    Error when using shell extensions and Total Commander
    29 Posts 3 Posters 21.5k Views
      Go to cmd.exe
      and run:
      regsvr32 /u PASHLEXT64.DLL
      it will unregister 64bit shell extensions!
      • PoooMukkelP Offline
        PoooMukkel
        That does not work. There appears an error which I only have in German.
        [Window Title]
        RegSvr32
        [Content]
        Fehler beim Laden des Moduls “PASHLEXT64.DLL”.
        Stellen Sie sicher, dass die Binärdatei am angegebenen Pfad gespeichert ist, oder debuggen Sie die Datei, um Probleme mit der binären Datei oder abhängigen DLL-Dateien auszuschließen.
        Das angegebene Modul wurde nicht gefunden.
          you need to navigate to PA folder first, or else specify the path before… like C:\program files (x86)\powerarchiver\pashlext64.dll
            PoooMukkel
            After that there are no shell extensions from PowerArchiver available although I checked the box in the settings. :(
              but you should have 32bit ones in TC? PA installs both x86 and x64 shell extensions.
                PoooMukkel
                No. There are no extensions from PA after that.
                  run this:
                  %windir%\SysWOW64\explorer.exe /separate, /root, c:
                  do you see PA shell there now?
                    PoooMukkel
                    Still no shell extensions from PA.
                      PoooMukkel
                      May be did you change something in PA2011 12.11 to solve this problem for me? ;)
                        PoooMukkel
                        No… It still does not work. :(
                          PoooMukkel,
                          Sent you a PM :)
                            bumping this thread again, should be fixed in .22
                            let us know
