    Delete archive on extract
    51 Posts 17 Posters 66.1k Views
      ArmedMonkey
      This is a feature I found useful in WinRAR and some other archivers. I think it is pretty simple to implement.
      I’d like a switch to prompt for deleting the archive(s) involved after an extract operation.
      I find myself downloading packages that are compressed, extracting them, and then deleting the archives right after. It’s small and silly, but I found the feature immensely useful.
        indeed that is a common practice of mine also…:)
        A 1 Reply Last reply Reply Quote 0
          ArmedMonkey @moles42
          Yeah, but for some reason this simple and intensely useful feature is not very widespread amongst different apps :(
          • W Offline
            wulffra
            Yes, I agree with this.
            Yesterday I extracted some 40-50 .RAR-sets, using the RMB.
            Extract to \subfolder.
            After extraction I needed to manually delete all files.
            PowerArchiver should have an option like:
            Delete .RAR’s after successful extraction”
            Hope there will be more support for this feature request…
              ArmedMonkey @wulffra
              I’m glad I’m not the only one who misses this. Hopefully the devs will take notice and implement it soon; I don’t think it should be very hard.
                issue here is that we cant implement it properly and make 100% sure that it is 100% failsafe. Only way i can see that happening is crc checking each file, which is not that simple and might be quite slow on some archive…
                  ArmedMonkey
                  Are you speaking in terms of making sure that everything is properly extracted without errors prior to deletion of the archives?
                  It could be an optional feature, the prompt, as well as the CRC checking.
                    drteeth
                    By ‘delete’ I hope and assume that one means ‘move to recycle bin’. If that is the case, I don’t see any problem in having this feature available.
                      ArmedMonkey
                      You could configure that perhaps.
                        spwolf conexware @ArmedMonkey
                        @ArmedMonkey:
                        and suddenly it becomes much more complicated ;-)
                        • manuangiM Offline
                          manuangi
                          I vote for this feature too. It would be great to have such a context menu entry as “extract + delete archive”…then in the options choose whether to move to recycle bin or delete for good.
                            ArmedMonkey @spwolf
                            Perhaps, but I don’t actually care about all the complicated stuff. AFAIK WinRAR, which I’ve used for years doesn’t do anything complicated. It just detects which archives were used, and deletes them. No CRC, No Recycle, etc.
                            I’ve never had a problem with it in all those years, and would be perfectly happy if it was implemented to the same minimal extent.
                            (I’ve never in all my years had a compression program extract something wrong. I’ve had corrupted FILES, but that causes an error on extraction due to the built-in CRC checks that I’m sure PA already performs. It performs those, right?)
                              @ArmedMonkey:
                              well you might not have an issue in the next few years either, but without properly doing it, someone might have an issue with it and someone might lose their files with it… this is why in general, we dont like deleting files without user interaction… something can always go wrong there.
                                ArmedMonkey
                                I understand what you’re saying and I appreciate your responses, but I’d just like to clarify. I never suggested that there be no user interaction. I mean a prompt that says “Delete?” at the end of each operation.
                                I’m not an expert on compressions, but if my memory serves me correctly, most compression formats store the uncompressed CRC hash of each file, I have received errors in 7zip, Winzip, and Winrar when the CRCs didn’t match up upon extraction. I haven’t used PA enough to encounter this, but I am assuming it does the check. So unless miraculously you have a combination of events which leads to a file being corrupted in the CRC table of the archive AND being extracted with an error in precisely the way which will cause the CRC to match up with the corrupted one, PA should detect that the operation failed and notify the user. Am I wrong?
                                With this said, in the case that your operation reports a success, the resultant files should be provably accurately decompressed versions of the bytes making up the archive(s) from which they were created.
                                At this point, what I am suggesting is, an option that users can enable (default is off), to show them a prompt when an operation has completed successfully, that asks if they would like to delete the archive(s).
                                • B Offline
                                  Big_Boss
                                  Yes, this would be a useful feature! SUPPORT! :)
                                  How it could work: an option in the configuration menu something like “Prompt for archive deletion after extracting archive”. The default would be no, so by default there would be no prompts to delete the archive after extraction and the archive would not be automatically deleted. If you changed that setting to yes, then every time you have extracted an archive PA would ask “Do you want to delete this archive?” or “these archives” if you extracted multiple archives or multi-part archive. If you say yes, the archive(s) is deleted into the Recycle Bin.
                                    spwolf conexware @Big_Boss
                                    @Big_Boss:
                                    sure, gang up on me!
                                    RJWaringR 1 Reply Last reply Reply Quote 0
                                      RJWaring @spwolf
                                      If its what the customers want Spwolf… :)
                                      I have to admit it would be a useful feature for the future.
                                        ArmedMonkey
                                        Sorry spwolf. Being a dev myself I know how you feel :P. You guys probably have your hands full with bigger stuff. But look on the bright side, all we actually want is a very simple implementation of what you’re talking about. Like I said, I personally don’t even care if it goes to the Recycle Bin, which is just a smidge harder than outright deleting the file.
                                          @ArmedMonkey:
                                          it is same if we delete to recycle bin or not, but when it comes to how complicated it is in total, it is as complicated at any other new feature… but we will put it on our list, cant promise anything else… thank you.
                                          D 1 Reply Last reply Reply Quote 0
                                            davidsplash @spwolf
                                            this feature is dangerous. the most safest way is to do this manually.
