An issue with 2010 Pro version
Yes my settings were on default.
Now I have changed them and registered and it’s back to slooooooooow mode :(
Yuck :(
Mame
12 seconds again or?
yes 12 seconds.
I leave my computer on as I mentioned and I guess after a while (number of hours) it “resets” back to 12 seconds on the first run and then a few seconds for the subsequent runs. This will repeat the next day when I come back from work so no way to know how many hour until the next "reset"back to 12 sec.
It’s something to do with the custom bars ( I use the classic buttons NOT the ribbon btw) and/or the registration. I do hope you guys get to the bottom of this.
As a comparison the latest Winrar beta fires up in under 1 second.
Good luck
Mame
you have explorer view on? It could be something like your hard drive coming out of sleep mode?
You can send us your registry settings (HKCU\Software\PowerArchiver), zipped, to support @ conexware . com.
I sent them in and I got some automated response. Hope you got them
Also: I disabled any type of power saving features. I have everythign on at all times. Monitor and HD.
Mame
Updates:
I have upgraded to Service Pack 2 (It was time)
A cold start is now 5 seconds and the subsequent one about 2 seconds.
Did the registry keys I sent reveal anything?
Mame
Updates:
Mame
nope, nothing interesting there. So you dont get that 12 seconds delay after you leave computer for several hours?
No but like I said I no longer have SP1 now I upgraded to Vista SP2. That may have somethign to do with it.
Mame
Weird.
Anyway, here is one of the last pre-release versions:
http://www.powerarchiver.com/test/release10/powarc1150final.exeWe worked hard to improved startup speed, it should be noticable in older computers, depending on settings used, this is now 30% faster at startup.
With the new version I got a 4 second first start and instant subsequent starts.
Mame
Edit: Spelling
Mame
Edit: Spelling
good…
