    An issue with 2010 Pro version
    29 Posts 4 Posters 19.3k Views
      registration is the same as in PA 2009, nothing changed there.
      What changed, and made PA 2010 slightly slower than PA 2009 was that compression engine is now loaded from the start up vs loading when used in PA 2009. So that adds slight delay at the start where that delay was previously there when you started adding or extracting from archives in PA 2009.
        Mameluke @spwolf
        I re-registered and rebooted.
        Back to 5 seconds and 2.5-3 seconds after that.
        Keep in mind that I lost my custom button arrangement (not using any outside skin or anything just had my button setup in my own way in the configuration menu) when i deleted the registry key so that may be a factor.
        I need to catch the Zzzz train so this will be my last post for the night.
        Once more to recap:
        2.4 Ghz Quad core
        4 gig ram
        Vista 64bit SP1
        Got the latest updates for the OS (minus SP2).
        Cheers and I hope you guys can get to the bottom of this.
        <3
        Mame
          spwolf conexware @Mameluke
          @Mameluke:
          Once more to recap:
          2.4 Ghz Quad core
          4 gig ram
          Vista 64bit SP1
          <3
          Mame
          yeah, that obviously makes the difference (not having any options than default).
          Its unclear to me if took 2 seconds first time and then 2 seconds afterwards so difference was between 5 and 2 seconds, or if difference was between 2 and 3 seconds :-).
          Also, when you re-registered (no need to rebot) did you keep rest of the settings default or?
            Mameluke @spwolf
            Once the registry entry was removed:
            It took around 2 seconds for both first as well as subsequent starts.
            Once registered with the new Rc5:
            5 seconds first start 2.5-3 seconds subsequent starts
            Seems to be something related to the registry for sure.
            Mame
              Mameluke
              Update:
              I never usually turn off my computer.
              I ran PA just now to double check and first run was 12 seconds again. ~2 seconds for the subsequent runs.
              I really dunno what is happening anymore. Am i the only one with this issue?
              Mame
                amh209
                My startup times appear to be 3-5 seconds on my laptop, I haven’t timed it on my desktop.
                  Mameluke @amh209
                  Yes my settings were on default.
                  Now I have changed them and registered and it’s back to slooooooooow mode :(
                  Yuck :(
                  Mame
                    @Mameluke:
                    Yuck :(
                    Mame
                    12 seconds again or?
                      Mameluke @spwolf
                      yes 12 seconds.
                      I leave my computer on as I mentioned and I guess after a while (number of hours) it “resets” back to 12 seconds on the first run and then a few seconds for the subsequent runs. This will repeat the next day when I come back from work so no way to know how many hour until the next "reset"back to 12 sec.
                      It’s something to do with the custom bars ( I use the classic buttons NOT the ribbon btw) and/or the registration. I do hope you guys get to the bottom of this.
                      As a comparison the latest Winrar beta fires up in under 1 second.
                      Good luck
                      Mame
                        you have explorer view on? It could be something like your hard drive coming out of sleep mode?
                        You can send us your registry settings (HKCU\Software\PowerArchiver), zipped, to support @ conexware . com.
                          Mameluke @spwolf
                          I sent them in and I got some automated response. Hope you got them
                          Also: I disabled any type of power saving features. I have everythign on at all times. Monitor and HD.
                          Mame
                            Mameluke @Mameluke
                            Updates:
                            I have upgraded to Service Pack 2 (It was time)
                            A cold start is now 5 seconds and the subsequent one about 2 seconds.
                            Did the registry keys I sent reveal anything?
                            Mame
                              @Mameluke:
                              Updates:
                              Mame
                              nope, nothing interesting there. So you dont get that 12 seconds delay after you leave computer for several hours?
                                Mameluke @spwolf
                                No but like I said I no longer have SP1 now I upgraded to Vista SP2. That may have somethign to do with it.
                                Mame
                                  Weird.
                                  Anyway, here is one of the last pre-release versions:
                                  http://www.powerarchiver.com/test/release10/powarc1150final.exe
                                  We worked hard to improved startup speed, it should be noticable in older computers, depending on settings used, this is now 30% faster at startup.
                                    Mameluke
                                    With the new version I got a 4 second first start and instant subsequent starts.
                                    Mame
                                    Edit: Spelling
                                      @Mameluke:
                                      Mame
                                      Edit: Spelling
                                      good…
