    Compress one file into multiple parts
    7402
    • K
      kpb
      Hello,
      I’m not sure if powerarchiver already includes this feature, i cant seem to find it though.
      Can powerarchiver include a feature that allows you to compress and create multiple parts of a file?
      For example, creating 7 rar/zip parts of a 700mb video file where each rar or zip file is 100mb big?
      • TBGBeT
        Yes, already possible - called SPANNING
        On the Add dialogue, select options and “Spanning”.
        You can select a size of each part (or choose custom to input the size).
        • K
          kpb
          thanks for the reply…appreciate it :)
