    Cd burn: split to several media
    4681
    • S
      suisse
      first of all, powerarchiver is great!
      CD Burn function is nice. I’d like a function to split a huge amount of files, for instance 10 GB of pictures, into several DVDs without having to create an archive!
      DVD1: files 1-100
      DVD2: files 101 - 200
      etc…
      • ivanI
        ivan conexware
        Actually you can now use 7Z or ZIP spanning feature to split to e.g. 4.5 GB and use also burning feature to burn to DVD.
        PA will ask you to insert second media, after first spanned archive is burned and second archive is ready to be burn on second media.
        • S
          suisse @ivan
          hi Ivan
          @ivan:
          Yes, I know that. But I do not want to create an archiver. Only burn the files and spilt them without creating an archive.
