    FTP Option does not work
    37 Posts 2 Posters 31.7k Views
      steiale
      I sent you the file.
      I checked several times the scheduler… Still not knowing where the problem is… I will keep on searching.
        did you check in Computer Managment> Task Scheduler? (or whatever it is called in Win2003)
          steiale
          Yes I did and in the properties “run only if logged on” is not checked. No idea why this is not working. I gave the task also the right user and pass…
            steiale
            Cant send you the pbs file. Its forbidden by our mailserver. Any other ideas…
              steiale
              I tried to send you the text output… Forbidden either… But I think I found the error.
              The alert thing backup done was enabled… I disabled it… We’ll see tomorrow…
                zip it and send it.
                Alert has nothing to do with task scheduler - it is problem with Win2003 task scheduler, as long as task is entered there, it has to run (nothing to do with PA itself anymore).
                  steiale
                  ok… Maybe I should write things a bit clearer.
                  One problem is that the task is not running in scheduler which is for sure a scheduler thing. Other tasks in scheduler do run perfectly on the same machine, so I thought it is maybe a small bug in writing fom PA to the scheduler in Win 2003.
                  Now behaviour is even stranger. The scheduled backup is stated running in the scheduler but no PA is started… This makes me going mad… :-)
                  The other problem was that PA is not closing after scheduled jobs. I found the error as I wrote above. You have to uncheck the alert. Maybe you should da this by default when having schedules tasks. If alert “backup done” is enabled then PA doen’t close after backup and stays open and in memory of course then.
                  Regards, Alex
                    aha, i understand better now - problem is that we dont know if schedule is done when user is not logged in or when they are logged in - meaning, if we disabled it, many people will complain for not getting the done msg (it happened before).
                    However we can leave an timer - that will work? Auto disable/ok after 10 minutes for example?
                      steiale
                      Perfect!!!
                        steiale @steiale
                        ok… everything seems to work now. I made a complete new pbs and scheduler job. This one runs now… No Idea why because it is exactly the same as the one one that didn’t run.
                        Thanks for the great support!!
