    PA2009 B1 & B2: No Shell Extensions
    29 Posts 10 Posters 21.5k Views
    • PoooMukkelP Offline
      PoooMukkel
      ^^That’s the same problem Cipher has posted already some answers ago… ;)
      @spwolf
      I’ll wait for the Beta 3. :)
      O 1 Reply Last reply Reply Quote 0
      • O Offline
        oxygen @PoooMukkel
        @PoooMukkel:
        i know, thats exactly what i mean.
        i just wanted to give spywolf my details, because i thought it would be a german vista x64 problem.
        • R Offline
          rasputin
          Hello,
          I’m having same problem too. Though “Shell extensions” are enabled on PA 2008 B2, they don’t show.
          I am using:
          Vista Ultimate 64Bit (German)
          PA 2009 B2 (German)
          I will quickly remove the german version and install the english version and see if it works.
          R 1 Reply Last reply Reply Quote 0
          • R Offline
            rasputin @rasputin
            Hello again,
            it seems indeed to be a bug in the german version of PA 2009 B2.
            I just installed the english version over the german one and shell extensions are there and everything works fine.
            Then I reinstalled the german version over the english one, and amasing, shell extensions still there but in english, though the program is now in german :-)
            • T Offline
              Tankred
              Thank you for testing! Are there any umlauts or special chars in the German version of the shell extension menu?
                spwolf conexware @spwolf
                so to clarify - it doesnt work in german PA, works in English (with some issues)…. quick fix is to uninstall german and install english.
                Both issues will be fixed in Beta 3 (english and german).
                • R Offline
                  rasputin @Tankred
                  @Tankred:
                  Not that I noticed; the shell extensions are completely in english, but if you reinstall the german version over the english version, you get the german interface of the program with english shell extensions.
                  As spwolf wrote, a “work around” if you can’t wait for B3 :-)
                    please try with beta 3 and let us know.
                    thanks…
                    C 1 Reply Last reply Reply Quote 0
                    • C Offline
                      cipher @spwolf
                      It seems to be working correctly now.
                      English PA 2009 Pro on English (U.S.) Vista Home Premium 64-bit
                        PoooMukkel
                        Yes! It works for me fine now!
                        German PA2009 on German Vista x64 and German Shell Extensions
                        Good job guys! :)
