    Shell Extension & Installer Improvements
    3631
    • H4ndyH
      H4ndy
      Here are two wishes:
      Installer:
      I would like to see an option to choose the Start Menu Subfolder. Also it would be great to be able unselect the Link to PowerArchiver which is placed under “all programs” over all subfolders.
      And why does PA reminds e.g. the interface settings but not the Shell Integration settings?
      And finally a small improvement:
      It would be nice if the “Shell Integration” option page would fit the window so theres more space for the selection controls and less scrolling work. Support for range select (using Shift) and the “Del”-Key as Shortcut for “Remove” would also be cool.
      Anyway, keep up the good work and greetings from Germany.
      Core i7-6700K, 16 GB DDR4-2666, GTX 980
      • TBGBeT
        @H4ndy:
        Try multiple select with Ctrl-Key instead of Shift-Key. :cool:
        H4ndyH 1 Reply Last reply Reply Quote 0
        • H4ndyH
          H4ndy @TBGBe
          @TBGBe:
          Yes I know, but I still like to have Range Select. But it’s a minor improvement if there will really be Patch-Updates with PA 2009 (so I don’t have to re-do the Shell settings with every update).
