    Small delay when compressing over Explorer contextmenu
    5077
    • M
      masu
      Hello,
      there is always a small delay if I try to compress files via the windows explorer contextmenu. Is this a bug. Can this behaviour be removed in the future versions of PA?
        @masu:
        Hello,
        you mean PA starting up? Is that what you experience? How long is the delay?
        • M
          masu
          maybe 0.5 sec
          the PA progress bar remains for this time at 2% after then the progress bar behave normally and runs to 100%
            i guess check it out with next PA and see if it still happens…
            • M
              masu
              when will the next version be released?
                spwolf conexware @masu
                @masu:
                trick question, eh? soon!
