PAOP: Files not being compressed
It’s been a couple of days. Any ideas of why it doesn’t work?
we are working on finalizing 10.20, so in few days we will have time to look at PAOP… thanks.
SPWolf,
Have the same problem here.
New windows instalation with:
PA 10.20.17
PAOP 2.00.08
Outlook 2003 SP2 11.8118.8132
MS Proofing Tools
Windows XP 5.1.2600 SP2 Build 2600I have been having this problem for a while and I have formatted my machine a installed the latest versions of PAOP and PA in order to see if the problem would be solved, but it didn´t. The PAOP 1.10 worked fine on my machine. Do you know if there is anyplace I can download the old version?
Thanks.
we will take an look at this this week, so please patient… we will need more info for sure.
thanks,
Found the 1.10 version in PA´s download site.
Uninstalled the 2.0 version, installed 1.10 and it works fine.
I´ll be waiting for a new version.
Here is what we need to know:
1. location of your temp folder
2. Send us paarcce.dat from your temp folder.You can send it to support conexware.com.
thank you!
Important - the parcce.dat must be the one that is created after reproducing the bug (creating new email message, adding attachment, clicking on “Compress” in PAOP dialog that shows upon “Send” action, and after loading/closing PA).
two things to ask what version of outlook are you using and what windows are you using. the second thing is to ask have you installed any other outlook plugin or have you reinstalled outlook after installing this plugin. i would suggest uniunstalling pa and outlook and pa and then install outllok then pa then this plugin and tell us what problems you encounter after that.
Windows XP Professional
Build 2600.xpsp_sp2_gdr.070227-2254 (Service Pack 2)Microsoft Office Outlook 2003 (11.8169.8172) SP3
Formatted my computer, installed Windows XP, Updated (Windows update), installed Office 2003, updated. Using a MSExchange connection.
The older version works fine. The newer doesn´t.
Couldn´t find the parcce.dat file.
check this out:
http://www.powerarchiver.com/test/release10/paop200.exeit should fix the issue. Please report back if it did.
