    Multi-Threading for ZIP
    4 Posts 4 Posters 5.2k Views
      masu
      new 7-zip beta version give support for multi-threaded zipping. can this function also be integrated into Powerarchiver.
        davidsplash
        i can’t see why not. the 7zip engine is sued by pa so it is possible to add that support in.
          TBGBe @davidsplash
          @davidsplash:
          What ? The “7-zip engine” is NOT used for ZIP files :confused:
          A 1 Reply Last reply Reply Quote 0
            amh209 @TBGBe
            Version 9.62 [May 2, 2006]
            Improved cancel in 7-Zip compress/extract
            Enabled multithreading mode for 7-Zip compression
            SO it already has been added, but what deos that have to do with Zip files?
