    The Windows 11 context menu for PowerArchiver on normal files (to be compressed, etc.) is now showing multiple tiers with two identical menus. See attached captures of the issue:
    Edition Windows 11 Pro
    Version 24H2
    OS build 26100.2605
    Hello!
    I’ve just created SFX-Archives both from ZIP and 7z-Archives and none has an Icon as it seems.
    I use the new version 22.00.11.
    Basically I used powerarchiver context menus to zip up a folder then i used windows 11 own built in zip extractor via the context menu to extract all and this is where it throw up a fault. , I’m using windows 11 .
    The file that was a problem in the zip that windows 11 could not extract was iva “babe” cotton.jpg
    I know it has non standard quotes in it.
    However I had winrar on the computer and tried the exact same method with their context menu compress to zip and then I extracted the file with windows own extract all context menu and it had no problems. This indicates that powerarchiver is doing something different with iva “babe” cotton.jpg compressing to zip.
    Then I changed iva “babe” cotton.jpg to iva babe cotton.jpg and compressed it with powerarchiver and then tried it with windows 11 extract all and had no problems. It looks like powerarchiver is doing something to that one file that has quotes in it.
    Please note that powerarchiver extracted both zip files with no problems, only windows built in zip extraction had the fault. Reason I’m letting people know in case they send zip files with special characters in files names to people who do not have powerarchiver.
    When will a fix be implemented?
    On installing the program I am getting the error message:
    "Unable to execute file c:\Program Files\PowerArchiver\pashutil.exe
    CreateProcess failed: code 2
    The system cannot find the file specified"
    This can’t be right!
    I am using the latest official build of Windows 11
    Buttons are not properly aligned on About screen.
    Buttons not aligned on configuration window.
    New version:
    PowerArchiver 2023 - 22.00.10:
    Download:
    https://u.powerarchiver.com/pa2023/powarc220010.exe
    New build for some bug fixes and issues - full list to come with new update. Please test and see if you have any issues.
    Thanks everyone for your assistance!
    New version:
    PowerArchiver 2023 - 22.00.11:
    Download:
    https://u.powerarchiver.com/pa2023/powarc220011.exe
    Just tried using the Modern (Windows 10) Icon set and seeing a few missing icons in both PowerArchiver Burner and PowerArchiver Encryption screens . They are all there in the Minimalistik icon set and the only difference I can see is the former is blue and the latter grey. In version 22.00.9
    I had a large .tar file (a backed up WSL) and I want to delete a few directories and their contents from it using PA2023.
    PA just destroys the whole archive as soon as I try to delete a directory, leaving it in a state where PA2023 won’t even open it any more.
    I tried several times and also tried compressing it to .tar.xz instead - same result.
    This should either actually work, or it should say operation not supported and do nothing.
    Hello!
    The regular version of PA 2023 is out for over 6 months now, but there is still no sign of the portable release.
    (When) will there be one?
    Thanks!
    PA2023: Portable version missing?
    Hello!
    Is there currently no portable version of PA2023 available?
    (When) do you plan to release one?
    Thanks!
    P
    Will you be releasing 2024 soon?
    PA 2023 Toolbox - 22.00.09 - Remove archive encryption
    Win 11 64 bit
    I have some archives which have been encrypted, using the encrypt option either in pbs or when interactively creating a zip. When I open these, and look at files, I am asked for passwords, which I know, and then can view items or decrypt the files in the archive (tools>decrypt files).
    However, when I use the Actions>Remove Archive Encryption (whether using the same zip or asking to write another), the routine shows progress bar to the end, but then just hangs i.e. “OK” never activates. All process information shows this stalled/hanging.
    What can I do to sort this out?
    Bug extracting from ZIP etc using Extract here with PA 22.00.09
    For example:
    Download this ZIP file: http://dslstats.me.uk/files/dslstats32W-6.5.zip
    Everything in the ZIP file is in a directory “dslstats32W-6.5”.
    However when I extract using right click “Extract Here” the name of the directory created is “2W-6.5” !
    I am running PA 22.00.09 on Windows 11. I have seen the same happen with some other kinds of archive too.
    Updates
    Any updates going to happen for the bugs reported?
    Multi Compress
    • I
      iwod
      While many program can Extract MutiPle Archive into Muti Folder. But i don’t find the option to compress Muti Folder into Muti Archive. Is this supported?
      And Explorer Mode Does not support Ctrl - A for select ALL.
      Header does not support Either unicode or chinese/Janpaness/Korean Characters.
      • TBGBeT
        Nobody answered :confused:
        OK. At present the “Multi” compression tool is Batch Zip Creation.
        It allows compression into any supported format (not only Zip) however, it does NOT support compressing Folders. Only the indivdual files will be compressed into seperate archives.
        Folder compression has been mentioned on wishlist forum a few times e.g.
        http://www.powerarchiver.com/forums/showthread.php?t=62
        For explorer view features - wait for 9.1
        http://www.powerarchiver.com/forums/showthread.php?t=96
