    Vista 64 and right-click drag
    30 Posts 7 Posters 24.3k Views
      2nd Try:
      http://www.powerarchiver.com/test/release10/powarc1001.exe
      Let me know if it works…
      skypxS spwolfS 2 Replies Last reply Reply Quote 0
      • skypxS Offline
        skypx @spwolf
        2nd Try:
        Downloading now. :)
        ASUS Crosshair VII Hero
        AMD Ryzen 9 5700X
        T-Force DDR4 3600 32GB
        Samsung 970 EVO 2TB
        GTX 3080ti
        Win10 x64
        skypxS 1 Reply Last reply Reply Quote 0
        • skypxS Offline
          skypx @skypx
          @skypx:
          Downloading now. :)
          All the options are not there yet.
          AMD Ryzen 9 5700X
          Samsung 970 EVO 2TB
          GTX 3080ti
          Win10 x64
            spwolf conexware @skypx
            @skypx:
            so there are more now?
            • skypxS Offline
              skypx @spwolf
              Yes, basically the “extract here” option is available.
              AMD Ryzen 9 5700X
              Samsung 970 EVO 2TB
              GTX 3080ti
              Win10 x64
              ivanI 1 Reply Last reply Reply Quote 0
              • ivanI Offline
                ivan conexware @skypx
                The issue should be fixed in 10.01.01. Thanks!
                • skypxS Offline
                  skypx @ivan
                  @ivan:
                  Cool!!!:)
                  AMD Ryzen 9 5700X
                  Samsung 970 EVO 2TB
                  GTX 3080ti
                  Win10 x64
                    spwolf conexware @spwolf
                    2nd Try:
                    you can try it again…. it is new version.
                    • skypxS Offline
                      skypx @spwolf
                      No change. I only have the option previously mentioned.
                      AMD Ryzen 9 5700X
                      Samsung 970 EVO 2TB
                      GTX 3080ti
                      Win10 x64
                      • ivanI Offline
                        You must restart computer because the DLL must be replaced. Maybe also try with clean install?
                        • skypxS Offline
                          skypx @ivan
                          @ivan:
                          I restarted the computer after the installation, but I did not do a clean install. I will and report the results.
                          AMD Ryzen 9 5700X
                          Samsung 970 EVO 2TB
                          GTX 3080ti
                          Win10 x64
                          • skypxS Offline
                            skypx @skypx
                            @skypx:
                            I uninstalled, restarted, installed, restarted, and unfortunately I still have the same options previously mentioned. Do I need a special tool to perform a clean install?
                            AMD Ryzen 9 5700X
                            Samsung 970 EVO 2TB
                            GTX 3080ti
                            Win10 x64
                              you still only get extract here option?
                              U 1 Reply Last reply Reply Quote 0
                              • U Offline
                                Uvi @spwolf
                                With the test version posted above and Vista x64 I now get Extract Here and Extract To options with a right click and drag operation.
                                • K Offline
                                  Kenneniah
                                  Same. Version 10.01.03 is now giving me the “Extract Here” and “Extract To” options so I’m happy.
                                    spwolf conexware @Uvi
                                    @Uvi:
                                    that is what you should get…
                                    • skypxS Offline
                                      skypx @spwolf
                                      I’m sorry to say that it’s not working as it should. The “Extract here” and “Extract to” options will extract all files to the same location. There is no option to extract a zipped folder to another folder within the target location. So if you right click and drag a folder named “files” to the e: drive, it will only extract the contents to the root drive and not to a folder called “files”.
                                      AMD Ryzen 9 5700X
                                      Samsung 970 EVO 2TB
                                      GTX 3080ti
                                      Win10 x64
                                      • W Offline
                                        wallan37
                                        I have the same issue as skypx, always extracts to the root directory. I am on day 25 of my trial and so far I am not convinced to buy :(
                                          spwolf conexware @wallan37
                                          @wallan37:
                                          you should definetly be very happy with it if you are considering purchasing….
                                            @skypx:
                                            I’m sorry to say that it’s not working as it should. The “Extract here” and “Extract to” options will extract all files to the same location. .
                                            ok
                                            H 1 Reply Last reply Reply Quote 0
