    PA 2007 installs not retaining previous settings
    36 Posts 10 Posters 28.9k Views
      amh209 @Cristian
      Not fix in 7, still had to enter all the reg info.
      B D 3 Replies Last reply Reply Quote 0
      • B Offline
        By-Tor @amh209
        Confirmed here too with beta 7. It would be nice to export settings just so we wouldn’t have to go through this - but, that’s a different issue. ;)
        spwolfS A 2 Replies Last reply Reply Quote 0
          spwolf conexware @By-Tor
          @By-Tor:
          we found another bug… it will be now fixed for… b9 :-).
          thank you guys - you can always export via regedit.exe and then just execute the .reg file after installation…
          • W Offline
            welhaux
            As others have stated, this is definitely NOT FIXED in Beta 7
              Ditto!
              I have actually designed my own regkey that will upload my Username, Serial aswell as my old prefered settings in order to save time as we are now in Beta 7 and still the settings don’t seem to save after an upgrade.
              In some new software programs when upgrading or uninstalling you have the option to keep or delete your current registry settings I would suggest that this might be an idea PA2008 Have or maybe a later release of 2007 Final.
                spwolf conexware @RJWaring
                @Sir:
                Ditto!
                again, it is an bug :-). It will still be reset in B8, but then it will work fine in B9 or final, whatever comes sooner :-).
                  davidsplash @amh209
                  this is still not fixed and it means i have to change the toobars and settings every install.
                  A 1 Reply Last reply Reply Quote 0
                    amh209 @davidsplash
                    Did they release beta 9 and I miss it?
                      spwolf conexware @amh209
                      @amh209:
                      no, just nobody is reading what I write anymore
                        try now guys…
                        NormandieN 1 Reply Last reply Reply Quote 0
                          amh209 @By-Tor
                          It worked for me! :D :D :D
                          • NormandieN Offline
                            Normandie @spwolf
                            try now guys…
                            Thanks spwolf, works for me!!! :D
                            Have a nice day,
                            Normandie
                            • ? This user is from outside of this forum
                              Guest
                              Fixed in PowerArchiver 2007 10.00.28 Beta 9
                                TBGBe @Guest
                                Just for fun err… testing, I uninstalled PA beta, rebooted, then installed PA 2006 and entered registration code.
                                Then I tried “upgrading” to Beta 9…
                                Of course, registration is “lost” - but the timer showed
                                Days Used : 16 (Out of 30)
                                Not sure where this came from, but I like it - two weeks to get the new/free code seems eminently fair.
                                Maybe in this specifc case (upgrade of registered version) there should be a text stating that new codes are needed and where to get them?
                                Even the skin was preserved when switching to classic view :cool:
                                The only other setting not preserved were the shell extensions - not really surprising.
                                  spwolf conexware @TBGBe
                                  @TBGBe:
                                  If you just installed PA 2007, it would be at 0. But uninstalling PA 2007 will not reset it to 0 :-)
                                    TBGBe @spwolf
                                    As I said I don’t think there is a problem it is just that
                                    if I uninstall PA 2007 and install PA 2006 it says:
                                    Days 842 (out of 30) - Expired :D
                                    And I was used to seeing that - earlier 2007 BETAs also told me that.
                                    Now if I uninstall PA 2007(B9) and install PA 2007(B9) it says:
                                    Days 16 (out of 30)
                                    That’s why I mentioned it.
                                    Maybe the 16 days used is just counted from installation of PA 2007 Beta 8 - but as I did enter register code for that I am not sure where it counts from :confused:
                                      @TBGBe:
                                      Days 16 (out of 30)
                                      We changed the the date for counting PA 2007 in one of the beta’s, so it counts from then… I am not sure exactly which one was it…
                                        TBGBe @spwolf
                                        Well I was just wondering if a first time upgrade from PA2006 to PA2007 will reset the counter to 0 for PA2007?
                                        There is another “problem” however.
                                        When upgrading from PA 2006 to PA 2007, the entry in Add/Remove programs for PA 2006 is not removed.
                                        So I now have two entries.
                                        If I now click to remove PA 2006 - it actually removes the installed PowerArchiver but leaves the entry for PA 2007 in Add/Remove programs :confused:
                                          You should uninstall PA 2007 and then PA 2006, and then install PA 2007.
                                          As to the counter, it is relative to when it is installed first on your system, which is why it shows you 16 days… to person who installs it today, it will be 0.
                                          thanks,
                                            TBGBe @spwolf
                                            So “upgrading” from PA2006 to PA2007 is not going to be possible - only clean install (with loss of settings).
