Shell extensions won´t work on 9.63.1
1. what happens when you want to add files to that archive?
2. If adding works, try “repairing” the archive via repair tool and then see if deleting works.Is there any way you can check “ownership” of the files? To see if possibly they are owned by another user.
And are you doing it under admin account?
No problem.
The files in zip archives are okay.
No I can’t.
Yes, my account is an admin account with all rights. Till the last update to 9.63 all functions are okay. it was possible to add and delete files to/from archive files without problems.
The zip archive with the problems is minimum 106 kB (with file setup.exe)
Please download it from http://www.leipzig-info.net/heiko/test_PAFixed.zip
Please delete the txt-file in zip archive and then the file setup.exe. Please try it several times.
Done that - still no problems (for me) :confused:
I also have no problems with the file. Is this the only file that has problems?
Guido
can you try resetting your settings back to default (under Options), and see if that works? It might be specific to certain setting you have.
thanks,
Wild guess (because of exe file) - do you have active scanning by an Anti Virus which could “lock” the temp file??
This could be possible. I have running an active antivirus program called “Panda Titanium 2006 Antivirus”.
But I can’t believe that this program is the cause for the problem. Till 9.63 I didn’t have any problems with deleting files from zip archives.
Now I will do reset the configuration of PA and will tell you the results.
yeah, try that and then try disabling AV and see if it works.
If I disable my AV it seems to work!!!
maybe report the issue to AV maker? They usually fix these issues…
