    Comment Window Pane: Remember Size?
    5527
    • MarcFouM
      MarcFou
      The comment window pane does not currently retain its size.
      Reproduce:
      1. Open an archive with a comment
      2. Resize the comment window pane
      3. Exit PA and reopen the archive
      4. Comment window pane is restored to default size
      *If you dont have comments ‘on’ then you can click the comment balloon in the lower right corner, and in the comment dialog check mark “Show comments”. Then you can use instructions above to reproduce.
        moved to the wishlist… thanks
        • MarcFouM
          MarcFou @spwolf
          I was actually debating if this qualified as a request or…? But as a wish, it seems like it may be a simple one :D
            spwolf conexware @MarcFou
            few other windows left to implement resizing for as well as saving the size of the window…
