    Archive Converter problems
    3
    5567
    • P
      Photofix
      I have downloaded the newest build (9.01). I have a project in which I have ALOT of SFX files to convert to zip files. Using the Archiver converter tool, I have run into a few issues that are causing be headaches.
      1.) I have to browse to each file (since each file in in a different folder) and each time I click on add a file, the tool starts the browse in the same folder each time no matter where I was last.
      2). The convert tool doesn’t see (.exe) files as a archive type. I have to select show all to see the SFX (.exe) files
      3). The context menus don’t display convert for the SFX (.exe) files but it will have extract, extract here. etc.
      If any one of these items be easier to work it would make much easier for me. If all were done I would be extatic. :D
      Thank you in advance for any help you can give on this.
      • TBGBeT
        Hmm I hadn’t realised that :(
        If you are looking for a suggestion to accomplish your task -
        Assuming you are familiar with DOS (Windows CMD)…
        Create a new Folder (e.g. c:\Manual )
        Now copy all the exe files (ctrl click) to this folder
        Then select all exe in c:\Manual and right click (to access PA shell extensions)
        Select Extract to Filename\
        This expands each exe into its own sub-folder
        Now delete all exe files
        Now use PACL (see download page) to compress each sub-folder into seperate (Zip or whatever) file.
        Check Ivan’s response here for a tip on how to do this
        http://www.powerarchiver.com/forums/showthread.php?t=100
        Note: Folders are “*.” in DOS Batch speak.
        Enhancing Archive Converter would make this much easier :D
        If you can find the old DOS ARJ32.exe archiver utility, it did include a (DOS) convert utility.
        Hope that helps.
        D 1 Reply Last reply Reply Quote 0
        • D
          davidsplash @TBGBe
          there is a contect setting thats sayes make sfx cab or zip
          if thats any help
