    .cbr?
    7
    9441
    • A
      Arrow
      Thanks for this program, I bought it after about two minutes of comparison with winrar. In other words, it’s almost perfect.
      However, can .cbr files be added to the list of associable file formats, please? I tend to run into those frequently.
      Thanks again
      -Arrow
        what is actually cbr?
        • S
          SoWhy
          It’s a format used for comic books and it stores the files in RAR-compression. See here: http://en.wikipedia.org/wiki/Comic_Book_Archive_file
          It would be nice to have it supported by PA in the future, because they are really just .rar-files filled with images and thus can be extracted just the same. In fact, manually opening them or renaming them does work, but things like multi-extract don’t.
          • S
            SoWhy @SoWhy
            bump
            Can this please be included? It really shouldn’t be hard to implement because the archive itself is already supported.
            • RJWaringR
              Is it an opensource archive format? if so I am sure it wont be a problem for powerarchiver to support it.
              • S
                SoWhy @RJWaring
                It is no format at all, just a renamed .rar file to work with CDisplay (see the Wikipedia-Link I posted). It is just a matter of PA recognizing and handling the format for purposes like multi-extract or “extract to”-shell extensions
                • RJWaringR
                  ow I see! Its type unknown to me. if thats just the case I can’t see the PA developers having a problem with it?
                  spwolf, Ivan? whats your response?
