    pacl900b-190606.exe (PACL 9.0 Beta 5) pacomp -r not working.
    I’m trying to backup the complete contents of a directory using: pacomp64 -parcz T:\BACKUP.PA C:\STUFF The contents of subdirectories of C:\STUFF isn’t getting backed up! The sub directories are just stored as empty directories!
    When extracting 7z files extract only newer files
    B
    How do I achieve this ; show me a command line example !
    Question Regarding License
    Hello @Mili, thanks for your help in getting my PowerArchiver CommandLine license (Re: License Code Not Working / Missing) and sorry for my late reply. I do check my spam folder regularly and couldn’t find a mail from support. Also, there was no mail in my backups or any mention of it in my email logs. I have a question regarding my licenses in the hope you are able to help me: While my account lists “PowerArchiver Select - lifetime free upgrades and support for PowerArchiver Toolbox English - Count 2”, this does not apply for PACL, which was included with my purchase. My account shows only PowerArchiver Select - 12 months of upgrades and support for PowerArchiver Command Line - Single User License. Since PACL was included with PowerArchiver Toolbox, shouldn’t PACL also come with a lifetime license for 2 PCs? Thanks for your help in advance.
    PACL 9.0 Beta 2
    Version: PACL 9.00 Beta 2 What’s New since version PACL 7: Updated to PowerArchiver 2017 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support and all the various engine updates done in PA 2017. Full support for .PA format with many different options and switches. Download: http://dl.powerarchiver.com/2017/PACL900-170429.EXE Due to the support of new PA format and all the changes needed for that support, we decided to move up version number to PACL 9. This is purely cosmetical - companies who purchased PACL8, have PACL9 now added to their orders. Users who have free upgrades for PACL8, now have PACL9 added as free upgrade (Business users with active select (pro/tbx), all personal users (pro/tbx). Since we are finalizing PA 2017, we can also now spend a lot more time on PACL9. Please check your bugs, and check .PA support as well. Thank you! @Alpha-Testers PA Team ConeXware, Inc.
    The PACL does not extract files from the self-extracting archive
    Michael72M
    My OS: Windows XP Home Edition, SP3 The version number and date of the program: PowerArchiver Command Line v9.00b [Feb 23 2019] The program not extracts one self-extracting file. How to reproduce the problem Download the SFX file by link: install.exe Copy the “install.exe” file into the same location as the program is located. Go to the DOS prompt. Make your PACL location the default drive. If it is on the E drive enter the command E: and press enter. Replace “E:” with the appropriate drive letter. Enter command cd e:<path name> to go to the location where the program resides. Enter command: paext32 -o+ -p"install" "install.exe" As a result, the “install” directory will not be created and no files will be extracted. The “install.exe” file may be damaged but if you use a program such as 7-Zip or PeaZip to extract the files, the extraction process is successful. I want the PACL to also unpack such a file. This problem is very critical for me. I often come across this. I do not want to resort to using other compression program. … Michael
    PACompXX problem with file name syntax
    czip support
    would be nice to have czip support
    PACL 8.0 Beta 1
    Version: PACL 8.00 Beta 1 Whats New: Updated to PowerArchiver 2016 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support such as improved ZIPX, ISO, etc, etc, etc. Download: http://dl.powerarchiver.com/2016/pacl800b1.exe Please test it against your existing scripts and let us know. There will be some features added in future release as well as more testing. This is first release, please test. Thank you!
    pacomp-exe-has-stopped-working)
    P
    I am Having Appcrash mid problem in my Pc.
    PAConv.bat
    Hi, I’ve made changes to fix some problems with PAConv.bat: 1. Replaced the “” by () in the first two lines, so that it’ll work with command line arguments in quotation marks 2. Replaced deltree with rmdir, since deltree is unknown at least in Windows XP and later 3. Also replaced the del command, which left an empty $PATEMP$ directory with rmdir 4. Changed $PATEMP$ to “%TEMP%$PATEMP$.%time::=%”, so that no write privileges are needed in the current directory as the users Temp directory is used and that more operations will work simultaneous, as long as they are not started at the very same time. 5. Changed %n to “%~n” to allow parameters with spaces and quotation marks if (%1)==() goto help if (%2)==() goto help SET PATMPDIR=%TEMP%\$PATEMP$.%time::=% if exist "%PATMPDIR%" rmdir /s /q "%PATMPDIR%" mkdir "%PATMPDIR%" paext -e -d -p"%PATMPDIR%" "%~1" echo. pacomp -a -r -p -w "%~2" "%PATMPDIR%\*.*" echo. rmdir /s /q "%PATMPDIR%" SET PATMPDIR=
    Profile Details
    B
    Why cant i edit my profile details? in my account
    Pacl 8.0
    PACL 8.0. What new features do you guys want from it? Current list for 8.0 RAR 5.x support. Latest ZIP/ZIPX engine with even better performance. Updated rest of engines with latest support for all file formats. Possibly: New PAF format testing. Other things like better logs or what else do we need?
    How to encrypt file names?
    Is it possible to encrypt file names as well as archive itself using pacl? I know you can do this using Power Archiver but not sure about pacl.
    Problem with large, spanned, encrypted, 7z archive.
    B
    I spent many hours trying to figure out how to use PACOMP to add about 50 Gb to a spanned 7z archive with AES256 encryption, and have yet to be successful. I’ve tried every combination of switches I can think of, with no success. Can someone offer a combination of switches that is known to work for this kind of task? All I have been able to make is a set of spanned files that PA cannot open.
    PACOMP -fips and -e2 commands
    Hi I am trying to understand what is default encryption method for PACOMP -fips command? And what is the difference if you specify encryption method using e[0,1,2] command? Using only FIPS: pacomp -a -ssecret -fips -p stuff.bh “c:\my stuff*.*” FIPS combined with e2 pacomp -a -ssecret -fips -e2 -p stuff.bh “c:\my stuff*.*”
    How to add archive comment using pacomp
    How can I add comment to archive using pacl pacomp?
    Extracting password protected archive.
    Hi All I have archive that holds password protected, encrypted data which is created using something like this: C:\Temp\ZipTest>pacomp -a -spassword -fips -e2 archive.zip "C:\Temp\ZipTest" -x"C:\Temp\ZipTest\ReadMe.txt" Then I add regular file into that archive which is not encrypted and not password protected. “ReamMe.txt” sort of file. Using command below. C:\Temp\ZipTest>pacomp -a archive.zip "C:\Temp\ZipTest\ReadMe.txt" Now when I extract this archive using: paext -spassword -p"C:\ZipTest\Temp" archive.zip Everything extracts correctly except for ReadMe.txt file. File is present but content is empty. I get following error: extracting: ReadMe.txt --> CRC ERROR! [100%] How can I extract archive without corruption ReadMe.txt file?
    Archive based on age
    O
    Does PA (preferably the CL version) have the facility to archive files based on an age? (I want to be able to move a quantity of files out of a folder and into an archive if (and only if) they’re over 35 days old. I have an ancient copy of ARJ that can do this (via the -odb switch) but I’d like to use PA, and can’t work out if it’s possible.
    Pacomp.vbs preserve the folder structure
    G
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    i have make file by powerarchiver 2011 with password put icant unzip it becouse i forget my password pls tell me what ido ineed unzip file
    Problem archiving from shares between 4.01 and 6.01
    48 Posts 5 Posters 50.7k Views
    • B Offline
      Badders
      I’ve just upgraded from 4.01 to 6.01 and now many of my archive jobs no longer work.
      The jobs archive data into a single zip from shares on different machines.
      Here is the job under 4.01:
      E:\PACL4>type pacl6prob.lst
      \\DTTST03\Data\pacltest\*.*
      \\DTRAH05\Data\pacltest\*.*
      E:\PACL4>pacomp -a -r -p -k -c2 PACL6prob.zip @PACL6prob.lst
      PowerArchiver Command Line (PACL)              Version 4.01       [Mar 07 2005]
      Copyright(c) 1999-2005 ConeXware, Inc.  All Rights Reserved. Registered Version
      This product is licensed to: Decision Systems Ltd
      Archive Compression Utility -- ZIP, CAB, LHA, BH, JAR, TAR, GZIP, BZIP2
        Internet: http://www.powerarchiver.com  Email: support@conexware.com
      Archive: E:\PACL4\PACL6prob.zip
        preparing to compress...
        adding: \\DTTST03\Data\pacltest\F1\FILE1.TXT   --> Done. [12%]
        adding: \\DTTST03\Data\pacltest\F1\FILE2.TXT   --> Done. [25%]
        adding: \\DTTST03\Data\pacltest\F2\FILE3.TXT   --> Done. [38%]
        adding: \\DTTST03\Data\pacltest\F2\FILE4.TXT   --> Done. [50%]
        adding: \\DTRAH05\Data\pacltest\F1\FILE1.TXT   --> Done. [62%]
        adding: \\DTRAH05\Data\pacltest\F1\FILE2.TXT   --> Done. [75%]
        adding: \\DTRAH05\Data\pacltest\F2\FILE3.TXT   --> Done. [88%]
        adding: \\DTRAH05\Data\pacltest\F2\FILE4.TXT   --> Done. [100%]
      E:\PACL4>paext -t PACL6prob.zip
      Archive Extr.---ZIP,CAB,LHA,ARJ,RAR,ARC,ACE,TAR,GZIP,BZIP2,UUE,ZOO,B64,YENC,...
      Archive --> E:\PACL4\PACL6prob.zip [ZIP]
        testing: DTTST03\Data\pacltest\F1\FILE1.TXT  --> OK [12%]
        testing: DTTST03\Data\pacltest\F1\FILE2.TXT  --> OK [25%]
        testing: DTTST03\Data\pacltest\F2\FILE3.TXT  --> OK [38%]
        testing: DTTST03\Data\pacltest\F2\FILE4.TXT  --> OK [50%]
        testing: DTRAH05\Data\pacltest\F1\FILE1.TXT  --> OK [62%]
        testing: DTRAH05\Data\pacltest\F1\FILE2.TXT  --> OK [75%]
        testing: DTRAH05\Data\pacltest\F2\FILE3.TXT  --> OK [88%]
        testing: DTRAH05\Data\pacltest\F2\FILE4.TXT  --> OK [100%]
      E:\PACL4>
      As you can see, the machine names and share names have been incorporated into the folder structure.
      This is the same job under 6.01:
      E:\PACL6>type pacl6prob.lst
      E:\PACL6>pacomp -a -r -p -k -c2 PACL6prob.zip @PACL6prob.lst
      PowerArchiver Command Line (PACL)              Version 6.01       [Feb 07 2010]
      Copyright(c) 1999-2010 ConeXware, Inc.  All Rights Reserved. Registered Version
      Archive Compression Utility -- ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
      Archive: E:\PACL6\PACL6prob.zip
         *** ERROR ():    DefaultDir
         *** WARNING: Nothing to add or update...
      1 error(s) encountered
      E:\PACL6>paext -t PACL6prob.zip
      Archive Extr.---ZIP,ZIPX,7Z,CAB,LHA,ARJ,RAR,ACE,TAR,GZ,BZ2,UUE,ZOO,B64,YENC,...
         *** Error: E:\PACL6\PACL6prob.zip not found
      E:\PACL6>
      Is there any way of making this work under version 6?
      Thanks,
      Badders
      • MickeM Offline
        Micke Alpha Testers
        Hi!
        I have made some tests on my own enviroment and I have also been successfull in recreating this problem.
        The problem appears in PACL 6.01 when you have more than one line in the listfile.
        Example of listfile that gives the same error message as you have:
        \\TESTPC\Install\PACL_Test\*.*
        \\TESTPC\Public\PACL_Test\*.*
        But if I remove one of the rows resulting in only one row in the listfile, then everything works ok.
        It looks like there can only be one line in the listfile or you will get this error. I need confirmation from the Administrators if this is correct or not.
        I suggest you test with only one line in your listfile for PACL 6.01 to confirm if you get the same results as I have.
        I have tested this with PACL 6.01 on Windows XP with SP3.
        Kind Regards
        Micke
        B 1 Reply Last reply Reply Quote 0
        • B Offline
          Badders @Micke
          Hi Micke,
          Thanks for looking into this.
          Agreed - It runs, but does not produce the correct results - the machine name and share name are not included in the archive.
          It looks there are two issues:
          1. Multiple lines in the list file:
          C:\Temp\*.doc
          E:\Temp\*.bat
          E:\PACL6>
          1. Storage of share names:
            adding: pacltest\F1\FILE1.TXT   --> Done. [25%]
            adding: pacltest\F1\FILE2.TXT   --> Done. [50%]
            adding: pacltest\F2\FILE3.TXT   --> Done. [75%]
            adding: pacltest\F2\FILE4.TXT   --> Done. [100%]
          All OK
          Archive --> E:\PACL6\PACL6prob.zip [ZIP]
            testing: pacltest\F1\FILE1.TXT  --> OK [25%]
            testing: pacltest\F1\FILE2.TXT  --> OK [50%]
            testing: pacltest\F2\FILE3.TXT  --> OK [75%]
            testing: pacltest\F2\FILE4.TXT  --> OK [100%]
          E:\PACL6>
          The above tests we’re run XP SP3.
          Under Windows Server 2003 R2 the results for multiple rows in the listfile appears to work (but not storage of shares):
          D:\Temp\PACL6>ver
          Microsoft Windows [Version 5.2.3790]
          D:\Temp\PACL6>type pacl6prob.lst
          \\SVWIN01\DSL\Misc\*.Doc
          \\SVWIN01\DSL\Temp\*.txt
          D:\Temp\PACL6>pacomp -a -r -p -k -c2 PACL6prob.zip @PACL6prob.lst
          Archive: D:\Temp\PACL6\PACL6prob.zip
            adding: Misc\Test.Doc   --> Done. [0%]
            adding: Temp\test.Txt   --> Done. [100%]
          All OK
          D:\Temp\PACL6>paext -t PACL6prob.zip
          Archive --> D:\Temp\PACL6\PACL6prob.zip [ZIP]
            testing: Misc\Test.Doc  --> OK [0%]
            testing: Temp\test.Txt  --> OK [100%]
          D:\Temp\PACL6>
          I use PACL extensively for backing-up multiple machines so this is a show stopper for me. Let me know if I can help further? (more tests, beta builds etc.)
          Thanks,
          Badders
          MickeM 1 Reply Last reply Reply Quote 0
            Hi guys,
            Let me confirm this:
            so there are 2 issues:
            1. You want drive/share included into the path
            2. If we have multiple share paths in list file, it will not work. Only single line works?
            B MickeM 2 Replies Last reply Reply Quote 0
            • B Offline
              Badders @spwolf
              Hi spwolf,
              For me it’s the "\<machine><sharename>" which need storing as folders - the same as in 4.01. I’m not sure what you mean by “drive”
              Correct
              Thanks.</sharename></machine>
                i think reason that worked in 4.01 was that it was not properly parsed out, while now we have properly parsed it out at runtime ;-).
                So basically, we will have to add option to include drive and share name in the future ;-)
                • B Offline
                  Badders @spwolf
                  I’m afraid that doesn’t make sense.
                  You’ve removed a clever and sensible piece of functionality which worked perfectly in the earlier version. Now you’re calling this functionality a bug :mad:
                  Which will be when? So far I’ve spent money on 6.01 and found it to be unusable.
                  • MickeM Offline
                    Micke Alpha Testers
                    Hi!
                    I can confirm that this listfiles works correctly in Windows XP Sp3 using PACL 6.01
                    Using driveletters
                    Q:\PACL_Test\*.*
                    Using \<machine><sharename>\
                    When running with a single line filelist that have either driveletter or \<machine><sharename>\ I get a successful result
                    Archive: C:\Programs\PACL\PACL6_Filelist1.zip
                      adding: PACL_Test\F1\FILE1.TXT   --> Done. [11%]
                      adding: PACL_Test\F1\FILE2.TXT   --> Done. [31%]
                      adding: PACL_Test\F1\FILE3.TXT   --> Done. [39%]
                      adding: PACL_Test\F2\FILE1.TXT   --> Done. [51%]
                      adding: PACL_Test\F2\FILE2.TXT   --> Done. [71%]
                      adding: PACL_Test\F2\FILE3.TXT   --> Done. [79%]
                      adding: PACL_Test\MANUAL.TXT   --> Done. [100%]
                    All OK
                    If the listfile has more than one row, it doesn’t work. I get the same error with driveletters and with \<machine><sharename>\
                    Q:\PACL_Test\*.*
                    R:\PACL_Test\*.*
                    Archive: C:\Programs\PACL\PACL6_Filelist2.zip
                    I think I can help you with this, by creating a script that will give you the same functionality in PACL 6.01 as you have in PACL 4.01. I can’t guarantee that it will work, but I’ll make some tests to see if it works or not.
                    This will be a workaround until a update of PACL 6.01 is available.
                    I’ll get back with more info when I have finished the script.
                    Kind Regards
                    Micke</sharename></machine></sharename></machine></sharename></machine>
                    • MickeM Offline
                      Micke Alpha Testers @Badders
                      @Badders:
                      I actually missed that, but I see now that the same thing happens for me. Now I’m not so sure that a script actually will solve it, but I’ll give it a try.
                      Kind Regards
                      Micke
                        spwolf conexware @Badders
                        @Badders:
                        It was an bug, that had functionality that you liked ;-).
                        It was one of the “bugs” that other users reported in PACL 4.x. Setting for saving drive letters and network shares is usually an extra option in compression applications, not an default one.
                        If you would preffer to use PACL 4.x, we will gladly issue an refund for you. Just send us an email to support@conexware with your order number and refference this thread. It is just that PACL 6 is really several magnitudes better product than PACL 4.
                        Both “issues” are not complicated to do, but I can not guarantee that version of PACL 6.02 will be out tomorrow. We have to finish other things we are doing right now and then move to PACL.
                        We had PACL in testing for this exact reason for a year and nobody reported anything in past quite few months. We do rely on our users to tell us how they use the product ;-). I am glad that more people are now telling us how they use PACL, thats really very helpful!
                        thank you…
                        • MickeM Offline
                          Micke Alpha Testers @spwolf
                          Personally I didn’t even think of that the drive letters and network shares wasn’t saved in the path for the files when creating archives. If this will be implemented in a future version of PACL maybe it then should be with an option if it’s to be included or not during archive creation.
                          What’s the idea of using a list file if it can only have one row in it? I haven’t used list files before because I haven’t used PACL for so long time yet. However IMHO there should be possible to have more than one line of paths to the files in a list file. Otherwise you can just put the path directly in the command when running PACOMP.
                          Kind Regards
                          Micke
                            spwolf conexware @Micke
                            @Micke:
                            Kind Regards
                            Micke
                            yeah, as i said, it would be an additional option. When it comes to PACL, people use it in various ways, so always good to have options.
                            As to the list issue, it is an bug, not intended behaviour!
                            • MickeM Offline
                              Micke Alpha Testers
                              Hi Badders!
                              Here’s a script for use with PACL 6.01. It will solve half of your problem by making it possible to have more than one row in a list file.
                              I have made it very simple for me, the script assumes that you have a maximum of 10 rows in the list file. It’s very easy to add more if you need to.
                              Here’s the code for the script. Copy the code and save it as PACOMP_List.vbs or whatever name you prefer.
                              '* PACOMP_List.vbs
                              '* @author:	Micke
                              '* @hist	2010-03-12	CREATED:Script for compress multiple file types
                              '*						using a listfile.
                              '* Usage: cscript PACOMP_List.vbs ArchiveName.extension ListFilePath
                              '* Example1: cscript PACOMP_List.vbs C:\Temp\MyArchive.zip C:\Temp\ListFile.txt
                              '* Example2: cscript PACOMP_List.vbs C:\Temp\MyArchive.zip D:\Test\FileLists.txt
                              Option Explicit
                              'Constants
                              'Variables
                              Dim FSO, objDir, aList(10), aPath(10), FileExtension, ArchiveName, ListFilePath
                              Dim aFile, aItem, strCompressionString, WshShell, objTextFile
                              Dim strCurrentLine, iCounter, strPath, DrivePath, strCurrentFileName
                              	WScript.Echo "Usage: cscript PACOMP_List.vbs ArchiveName.extension ListFilePath"
                              	WScript.Echo "Example 1: cscript PACOMP_List.vbs C:\Temp\MyArchive.zip C:\Temp\ListFile.txt"
                              	WScript.Echo "Example 2: cscript PACOMP_List.vbs C:\Temp\MyArchive.zip D:\Test\FileLists.txt"
                              	WScript.Quit
                              End If
                              ListFilePath = WScript.Arguments.Item(1)
                              'Read data from ListFile
                              If FSO.FileExists(ListFilePath) Then
                              	ReadFromListFile()
                              Else
                              	WScript.Echo "Could not find ListFile"
                              	WScript.Echo "Path to ListFile set as: " & ListFilePath
                              	WScript.Echo "Unable to continue script, exiting..."
                              	WScript.Quit
                              End If
                              'Check the filetypes in the ListFile
                              CheckFileTypes()
                              Sub ReadFromListFile()
                              	iCounter = 0
                              	Set objTextFile = FSO.OpenTextFile(ListFilePath, 1)
                              	Do Until objTextFile.AtEndOfStream
                              		aPath(iCounter)= objTextFile.ReadLine
                              		iCounter = iCounter + 1
                              	Loop
                              	objTextFile.Close
                              End Sub
                              Sub CheckFileTypes()
                              	'Check the Array of FilePaths
                              	For Each strPath In aPath
                              		If Len(strPath) > 0 Then
                              			'Get the FileName from the path
                              			strCurrentFileName = Mid(strPath, InStrRev(strPath, "\")+1)
                              			'Check if FileName is not set as *.*
                              			If strCurrentFileName <> "*.*" Then
                              				'Get the Path without the FileName
                              				strPath = Left(strPath,Len(strPath)-Len(strCurrentFileName))
                              				'Get the FileExtension
                              				FileExtension = LCase(Right(strCurrentFileName, 3))
                              				'Set the current folder to start searching from
                              				Set objDir = FSO.GetFolder(strPath)
                              			Else
                              				AddAllFilesToArchive(strPath)
                              			End If
                              		End If
                              	Next
                              End Sub
                              		End If
                              	Next
                              	Next
                              End Sub
                              	strCompressionString = PACOMP & " -a -p -k -c2 " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34)
                              End Sub
                              Sub AddAllFilesToArchive(pstrFileName)
                              	strCompressionString = PACOMP & " -a -r -p -k -c2 " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34)
                              End Sub
                              I don’t know if you have any use of this. I only wrote it because it’s fun writing scripts as workarounds for problems :)
                              The script is only tested with PACL 6.01 on Windows XP Sp3.
                              Kind Regards
                              Micke
                                For what it is worth, I have only used @list with filenames (not folders) and then multiple lines works OK
                                (easier as the names don’t have to be quoted when spaces are in path/name).
                                  Micke is spoiling us with his scripts ;-).
                                  • MickeM Offline
                                    Thanks, now I feel an obligation to continue writing scripts for use with PACL when users report new problems :)
                                    Kind Regards
                                    Micke
                                    • B Offline
                                      Badders @Micke
                                      Wow - so much interest :)
                                      First of all, thanks for everyone’s contributions and especially Micke for the script. I’ve downloaded it and it works fine for issue 2, “multiple rows in listfile”:
                                      E:\PACL6>ver
                                      Microsoft Windows XP [Version 5.1.2600]
                                      E:\PACL6>cscript pacl6probscript.vbs PACL6prob.zip PACL6prob.lst
                                      Microsoft (R) Windows Script Host Version 5.7
                                      Copyright (C) Microsoft Corporation. All rights reserved.
                                      E:\PACL6\PACOMP.exe -a -r -p -k -c2 "PACL6prob.zip" "\\DTTST03\Data\pacltest\*.*
                                      E:\PACL6\PACOMP.exe -a -r -p -k -c2 "PACL6prob.zip" "\\DTRAH05\Data\pacltest\*.*
                                        testing: pacltest\  --> OK [100%]
                                        testing: pacltest\F1\  --> OK [100%]
                                        testing: pacltest\F2\  --> OK [100%]
                                      E:\PACL6>
                                      Regarding the second, and more important, issue for me, I’d be happy with an option to store the machine & share names. Options are good :D
                                      I guess we’ll have to agree to disagree on whether a developers “tidying up”, affecting functionality of the product, is right. If other users are reporting it as a bug then a decision has to be made, one way or the other - which is what’s happened. Unfortunately, this time, I was at the wrong end of the decision.
                                      Regarding a refund? I don’t one. I think I’ve had real value for money from PACL and wish to contribute to it’s continued development. Version 6 does offer so much more (as you say) and I like the way coneXware operates. I do feel a little guilty that I didn’t test the version 6 beta as these issues would have surfaced much earlier.
                                      Keep up the good work guys and here’s looking forward to 6.02. Let me know if I can help with testing etc.
                                      Badders
                                        thank you badders! Better check our future betas so there wont be any surprises ;-).
                                        As i said before, we warmly welcome more advanced users for PACL to the forums, so you can tell us better how you use PACL. Without that, we are just guessing!
                                        thanks.
                                        • MickeM Offline
                                          Micke Alpha Testers
                                          Hi Badders!
                                          It’s nice to hear that the script works for you. As always there’s a risk of something missing and you don’t see it until someone else is testing it.
                                          Kind Regards
                                          Micke
                                          • B Offline
                                            Badders @spwolf
                                            Ouch!
                                            Certainly will. I’ll have a think and let you know.
                                            (Thank you again Micke for your work on the script alternative)
                                            Cheers,
                                            Badders
