PA 2006 new skins problem
Very very nice the new skins but not quite right yet (for my taste anyway). I used 4 of my PCs to try your new skins. On three of them running Win 98 SE the toolbar does not show the right color and on my WinXP pro PC the colors are ok. But on all 4 machines when I open a file there’s a lot of flashing going on especially at the top before the file’s content appears in the window is that supposed to be ok???
- check beta 5 for flashing issue.
- how do you mean doesnt show right color?
By not right I mean that for example the toolbar is a bluish green with the skin Green Metal on my WinXP pro PC just like the picture on your Web site shows but on 3 machines running Win98SE the toolbar color is kind of light brown like the color of the columns titles but darker.
please check flickering problem with Beta 5 which is posted right now. And if Win98 problem still happens, send us screenshot please.
I am using Beta 5 in XP. The flashing problem is greatly reduced - still some but not as annoying as it was before.
In addition, I don’t know if anyone has pointed this out but the Minimize, Expand and Close buttons are missing from the Elegant skin - check the skins download page.
BTW, nice job! I am using Modern.
they are not missing, thats the design (you notice there are 3 buttons)…
Neat!!!
Any way of making them slightly bigger?
Thanks
