    Open source
    Could powerarchiver be open sourced as I fear it is going to be lost once you decide to stop development on it.
    7-zip problems AGAIN AND AGAIN AND AGAIN AND AGAIN…..
    53 Posts 9 Posters 64.7k Views
    • H Offline
      HandsomeGuy @TBGBe
      I just did a quick test right now.
      I went to the X-Setup Pro folder and selected all the files and folders and right click and selected to compress to 7z. I then did the same using WinRAR. I then compared what showed up by opening then both in WinRAR.
      Two folders were missing from the PA created 7z. These folders were Plugins and Wizards, and when I checked, these folders were both blank.
      You guys try it and let me know if you get the same thing.
      This is still a problem, as what if these blank folders are needed and PA doesn’t recreate them? Can this problem PLEASE be fixed for the next beta? I don’t want to see anything missing, no matter how insignificant PA deems it. I chose what to compress, and hence it should ALL be there.
      This is only one thing at the moment. I will try other things are I get more time.
      PS: Can I pls get a registration code for PA 2006, as I’m willing to provide my services as a beta tester for it.
      Thanks.
      ivanI TBGBeT 2 Replies Last reply Reply Quote 0
      • ivanI Offline
        ivan conexware @HandsomeGuy
        We fixed the problems with saving path, and now working on saving/restoring empry folders. All those things should be for BETA 4.
          TBGBe @HandsomeGuy
          @HandsomeGuy:
          The beta versions are released for public testing. You do not need a registration code to contribute to beta testing - just post here in the forums when you find problems.
          Actually, it is useful if some “beta testers” are unregistered, just to verify that there are no errors introduced which only affects them.
          PS
          :D if you really want a registration code http://www.conexware.com/order.html :D
          H 1 Reply Last reply Reply Quote 0
          • H Offline
            HandsomeGuy @TBGBe
            Yeah, gee thanks. We can’t even get 1 code for helping testing.
            A 1 Reply Last reply Reply Quote 0
              amh209 @HandsomeGuy
              We are all helping to make the code better. PA is a small company that is trying to provide a good rpoduct and working hard to make it affordable for home users. Along with this, they have always been very responsive with their support. I for one think that your attitude stinks and I’m tired of listening to you trash PA and complain because you can’t get something for free. If you don’t like the program, quit using it. If you want to help improve the product, offer insightful suggestions and detialed descriptions. IF you want something for free, go find an open source program. If you want to get paid, apply for a job and prove your worth.
              Last time I will be replying to any of handsomeguys comments.
              spwolfS H 2 Replies Last reply Reply Quote 0
                spwolf conexware @amh209
                easy…
                From beta 4, empty folders are added to the 7zip archives.
                regards,
                • H Offline
                  HandsomeGuy @spwolf
                  easy…
                  regards,
                  Great. Thanks a lot. I can’t wait to give it a try. When will beta 4 be out? Also, what other changes does it contain?
                  • H Offline
                    HandsomeGuy @amh209
                    @amh209:
                    Relax man. I hear ur comments. I too wanna help improve PA. Ur just takin things too personal. I’ve helped test other products n got free registration codes before, so I was just seeing in PA would be the same. Just relax man.
                      TBGBe @HandsomeGuy
                      @HandsomeGuy:
                      In case you missed it - it’s out now :D
                      • H Offline
                        HandsomeGuy @TBGBe
                        Yeah, I just saw. Hope to give it a try on the weekend, time permitting. Good on ya guys.
