    Wider dialog window for Add…
    13
    9223
    • C
      Carlospr
      I’ve installed PA 2006.
      However, the “Add” dialog window could be wider.
      The “Add to archive” text box is small and I always have to press “End” key to go to the end of the line and then change the archive’s name.
      In addition, the text box of the password field could be placed in the “Add” dialog instead of just a button…
      Maybe for this major release, you could make this adjustments to make not only easier but also faster for add with options…
      • K
        klumy
        I agreee with you ;)
        C 1 Reply Last reply Reply Quote 0
        • C
          Carlospr @klumy
          Thanks Klumy!
          I really hope they update the old interface…
          • C
            Carlospr @Carlospr
            Here is my suggestion of a new Add dialog which is just easier (faster) to use:
            K 1 Reply Last reply Reply Quote 0
            • K
              klumy @Carlospr
              Perfect !!!
              R 1 Reply Last reply Reply Quote 0
              • R
                Ricco @klumy
                Very nice!!!
                • K
                  klumy @Ricco
                  the Drag and drop window in beta 3 already has such a design
                  we are just waiting for the add dialog ;)
                  • C
                    Carlospr @klumy
                    It’s really better!
                    But I still think a password field is better then a button. I always use password…
                    PA new after drop window dialog (see my suggestion above):
                    • TBGBeT
                      TBGBe @Carlospr
                      @Carlospr:
                      Don’t you need TWO fields - enter and confirm :confused:
                      • C
                        Carlospr @TBGBe
                        Yes, two fields.
                        B 1 Reply Last reply Reply Quote 0
                        • B
                          By-Tor @Carlospr
                          I support the idea of making the add box wider instead of having it as long as it is.
                            spwolf conexware @By-Tor
                            i am not sure if we can resize it properly because of the options tab options. we will check it out.
                            • C
                              Carlospr @spwolf
                              Thanks!
                              With an application like PA the less mouse clicks the better is the user interface!!
                              I use PA everyday for my backups! It’s important to get a fast access to the options.
