    Create .tar.gz2, .rar and .ace directly from shell-extension menu
    11
    11806
    • T
      tormen
      Hi.
      Are there plans to include one of or all of the following formats for archive-creation:
      tar.bz2 DIRECTLY from the context (shell extension) menu
      .rar at all (and from the context (shell extension) menu
      .ace at all (and from the context (shell extension) menu
      As I was using .rar I would like to change, but only if I can also create .rar files.
      Greetings,
      tormen.
      • K
        klumy
        RAR and ACE are licensed formats.
        no chance to integrate them in PA
        R 1 Reply Last reply Reply Quote 0
        • R
          Ricco @klumy
          Actually other than WinRAR and WinACE themselves, no other archivers provide creation (Extraction support is provided free-of-charge) on these two formats. They’re licensed formats and ConeXware would be charged for the license fee if PA supports these formats. It can result in the increase of PA price (only if PA really integrates these support).
          J 1 Reply Last reply Reply Quote 0
          • J
            jowood @Ricco
            license.txt from unrar source package v2.0:
             ******    *****   ******   unRAR - free utility for RAR archives
             ******   *******  ******    License for use and distribution of
             **   **  **   **  **   **         FREE portable version
                  The source code of unRAR utility is freeware. This means:
               1\. All copyrights to RAR and the utility unRAR are exclusively
                  owned by the author - Eugene Roshal.
               2\. Anyone may use the utility unRAR and it's source code to handle
                  archive files created with the RAR archiver without limitations.
               3\. The unRAR utility may be freely distributed, provided the
                  distribution package is not modified.  No person or company
                  may charge a fee for the distribution of unRAR without written
                  permission from the copyright holder.
               4\. THE RAR ARCHIVER AND THE UNRAR UTILITY ARE DISTRIBUTED "AS IS".
                  NO WARRANTY OF ANY KIND IS EXPRESSED OR IMPLIED.  YOU USE AT
                  YOUR OWN RISK. THE AUTHOR WILL NOT BE LIABLE FOR DATA LOSS,
                  DAMAGES, LOSS OF PROFITS OR ANY OTHER KIND OF LOSS WHILE USING
                  OR MISUSING THIS SOFTWARE.
               5\. Installing and using the unRAR utility signifies acceptance of
                  these terms and conditions of the license.
               6\. If you don't agree with terms of the license you must remove
                  unRAR files from your storage devices and cease to use the
                  utility.
                  Thank you for your interest in RAR and unRAR.
                                                        Eugene Roshal
            ```So if you read the unrar sources and if you understand how the decompressor works you can easily write a RAR compatible compressor to create RAR 2.x archives without paying any license fees. The RAR format itself (as any other archive format) and the compression algorithm (lzh) are not copyright protected. There are also some archivers out in the world which can create RAR (and ACE) archives.
            • R
              Ricco @jowood
              Well… you should notice the License.txt from WinRAR…
              here comes the quote
              Neither RAR binary code, WinRAR binary code, UnRAR source or UnRAR
              binary code may be used or reverse engineered to re-create the RAR
              compression algorithm, which is proprietary, without written
              permission of the author.
              R J 2 Replies Last reply Reply Quote 0
              • R
                Ricco @Ricco
                And may I know which archivers support the creation of RAR and ACE? I’m interested in that.
                • J
                  jowood @Ricco
                  @Ricco:
                  This was added in last versions of WinRAR and UnRAR (3.x) but it does not affect the previous versions of license.txt (2.x).
                  @Ricco:
                  Sure. Squeez (archiver), SpeedCommander and The Next Tool (file managers with great archive support).
                  • R
                    Ricco @jowood
                    Thanks! But actually how is the efficiency of RAR v2.x when compared it with V3.x?
                    • R
                      Ricco @Ricco
                      I’ve tried creating RAR using Squeez. It’s quite nice though not V3.x. Hope ConeXware could consider supporting it.
                      • J
                        jowood @Ricco
                        @Ricco:
                        RAR 2.x is much better than ZIP and today nearly everyone can extract RAR files. :D
                        IIRC RAR 3.x offers better compression for text files (PPMD) and for RGB files (delta coder).
                        • C
                          cds333
                          This post is deleted!
